Duplicated IPMI settings
see Power settings for multiple machines linked
I found that two machines “A” and “B” had the same IP address configured for their IPMI/LAN 2.0 IP address. I figured out that B was wrong, so I fixed it using the GUI. The address for A was also changed AND that address appears to also be in use by system “C”.
I deleted system “C” because I did not know the correct values and it was not in use.
For system “A”, I changed the config from IPMI to redfish, set the IP, saved it, then set it back to IPMI/LAN 2.0 and saved again and now the two systems seem to be separated.
So I guess this is more of a FYI then anything else.
we’re on 3.2.11 and I know we need to upgrade…
