This was previously posted and ‘closed’ with a solution so I was unable to reply to that posting. The solution posted does not work.
There are multiple servers that need to boot from their internal hard drives and not from PXE/MAAS. How-ever I do not want to turn off PXE as this is a fall back solution if the drives fail or troubleshooting is needed on the server.
The solution posted was
Disable automatic enlistment/commission and shutdown
root@maas:~# maas $PROFILE maas set-config name=enlist_commissioning value=false
OK
I took a server that was not in MAAS and I rebooted and it went into a PXE boot and then enlisted in MAAS, which is supposed to be turned off. Is there any option for this? I was hoping I could add it as a ‘device’ and MAAS would ignore it. But that does not work either.
MAAS running via snap 3.3.2-13177-g.a73a6e2bd
