During machine enlistment, deployment, commissioning and machine installation, MAAS sends Tempita-derived configuration files to the cloud-init process running on the target machine. MAAS refers to this process as preseeding.These preseed files are used to configure a machine’s ephemeral and installation environments and can be modified or augmented to a custom machine configuration.
Customisation in MAAS happens in two ways:
- Curtin, a preseeding system similar to Kickstart or d-i (Debian Installer), applies customisations during operating system (OS) image installation. MAAS performs these changes on deployment, during OS installation, but before the machine reboots into the installed OS. Curtin customisations are perfect for administrators who want their deployments to have identical setups all the time, every time. This blog post contains an excellent high-level overview of custom MAAS installs using Curtin.
- Cloud-init, a system for setting up machines immediately after instantiation. cloud-init applies customisations after the first boot, when MAAS changes a machine’s status to ‘Deployed.’ Customisations are per-instances, meaning that user-supplied scripts must be re-specified on redeployment. Cloud-init customisations are the best way for MAAS users to customise their deployments, similar to how the various cloud services prepare VMs when launching instances.
Curtin
Templates
The Tempita template files are found within the /var/snap/maas/current/preseeds/
for the snap and /etc/maas/preseeds/
directory for the debian package on the region controller. Each template uses a filename prefix that corresponds to a particular phase of MAAS machine deployment:
Phase | Filename prefix |
1. Enlistment | enlist |
2. Commissioning | commissioning |
3. Installation | curtin (Curtin) |
The enlist
template, for example, contains only minimal variables, whereas enlist_userdata
includes both user variables and initialisation logic.
Tempita’s inheritance mechanism is the reverse of what you might expect. Inherited files, such as enlist_userdata
, become the new template which can then reference variables from the higher-level file, such as enlist
Template naming
Some earlier versions of MAAS only support Ubuntu. If the machine operating system is Ubuntu, then filenames without {os}
will also be tried, to maintain backward compatibility.
{prefix}_{os}_{node_arch}_{node_subarch}_{release}_{node_name}
or{prefix}_{node_arch}_{node_subarch}_{release}_{node_name}
{prefix}_{os}
{prefix}
generic
The prefix can be either enlist
, enlist_userdata
, commissioning
, curtin
, curtin_userdata
or preseed_master
. Alternatively, you can omit the prefix and the following underscore.
For example, to create a generic configuration template for Ubuntu 16.04 Xenial running on an x64 architecture, the file would need to be called ubuntu_amd64_generic_xenial_node
To create the equivalent template for curtin_userdata, the file would be called curtin_userdata_ubuntu_amd64_generic_xenial_node
Any file targetting a specific machine will replace the values and configuration held within any generic files. If those values are needed, you will need to copy these generic template values into your new file.
Configuration
You can customise the Curtin installation by either editing the existing curtin_userdata
template or by adding a custom file as described above.
Curtin provides hooks to execute custom code before and after installation takes place. These hooks are named early
and late
respectively, and they can both be overridden to execute the Curtin configuration in the ephemeral environment. Additionally, the late
hook can be used to execute a configuration for a machine being installed, a state known as in-target.
This syntax won’t work because the value of sh
's -c
argument is itself an entire command. The correct way to express this is:
early_commands:
late_commands:
