2.7 | 2.8 | 2.9 | 3.0 | |
MAAS doesn’t support TLS encryption natively. If you are not interested in setting up an HAProxy, you can enable TLS independently in the web server software (e.g. Apache, Nginx) which users access directly. The examples below explain how to create this configuration.
Note that MAAS doesn’t bind to port 80; instead, MAAS binds to port 5240.
nginx example config
server {
listen 443 ssl;
server_name _;
ssl_certificate /etc/nginx/ssl/nginx.crt;
ssl_certificate_key /etc/nginx/ssl/nginx.key;
location / {
location /MAAS/ws {
proxy_http_version 1.1;
apache2 example config
<VirtualHost *:443>
SSLEngine On
SSLCertificateFile /etc/apache2/ssl/apache2.crt
SSLCertificateKeyFile /etc/apache2/ssl/apache2.key
RewriteEngine On
RewriteCond %{REQUEST_URI} ^/MAAS/ws [NC]
RewriteRule /(.*) ws://localhost:5240/MAAS/ws [P,L]
ProxyPreserveHost On
ProxyPass / http://localhost:5240/
ProxyPassReverse / http://localhost:5240/
</VirtualHost>
