Configuration journey (UI)
http://${API_HOST}:5240/MAAS
Configuration
config-journey-ssh-keys
In the source dropdown, select “Launchpad,” “Github,” or “Upload.” If you choose one of the first two, you will need to enter your username for that service. For example, if you want to upload your SSH public key from Launchpad, you would enter:
lp:<username>
gh:<username>
pasting-ssh-keys
Networking
discovery
[note]
Network discovery can be disabled at any time from the button on the Dashboard view. Also note that you can get back to the dashboard at any time by clicking the MAAS logo.
fabrics-etc-example
Be aware that these network settings are spread across several web UI configuration pages. The Zones page, for example, enables you to see how many machines, devices and controllers are using a zone, and allows you to add and edit zones. The Subnets page, shown below, provides access to fabric, VLAN, subnet and spaces configuration.
subnet-list-full
Deployment
MAAS-managed machines are listed – and operated on – from the Machines page, making it one of the most important screens in the MAAS web UI:
deploying-machines
If you are testing MAAS using virtual machines, the machines appear here as soon as they boot. New machines are added automatically when they first connect to your network. Alternatively, the ‘Add hardware’ menu lets you add machines manually, via their MAC address.
After you configure power and interfaces, MAAS must commission machines to retrieve CPU, memory and storage information. From this point, you can command MAAS to acquire, test, deploy and release these machines as you work with your MAAS cloud.
While you are testing MAAS, be sure to check out filters, which can narrow your view based on both tags and hardware characteristics. You can select and manage machines in either filtered or full views.
Images
When it comes to running applications, MAAS can easily deploy any supported variant of Ubuntu, including LTS and non-LTR versions for x86, ARM, PPC and s390x systems. You can also deploy several other operating systems to your machines, including CentOS 7, CentOS 6, Windows, RHEL, and ESXi images, via Ubuntu Advantage.
images-menu-screen
VM hosts
VM hosts can give you greater control over your hardware. A VM host is a collection of individual virtual machines. You can use a VM host to compose machines into an abstraction of resources that functions like a physical machine – without building one! It’s easy to add a VM host: click the “Add KVM” button on the “KVM” page of the web UI, give the VM host a name, and select “Virsh” as the VM host type. You will also need to enter the address for the libvirt controlled pool below.
After you create a VM host, you compose hardware by selecting the VM host, and then selecting “Compose” from the Action menu. You can configure composed hardware as desired, including the number of cores, CPU speed, RAM and combined storage. Then just click “Compose machine”, and MAAS will combine resources to create a new, single entity that can be used just like any other machine. VM hosts abstract multiple resources:
pod1
into pools of composable hardware:
compose-machine
