maas admin --help
MAAS CLI help, sample output
usage: maas admin [-h] COMMAND ...Issue commands to the MAAS region controller at http://192.168.43.251:5240/MAAS/api/2.0/.
optional arguments:
drill down:
COMMAND
boot-source-selection
boot-source-selections
commissioning-script
commissioning-scripts
dnsresource-records
TXT)
domain Manage domain.
domains Manage domains.
fabric Manage fabric.
fabrics Manage fabrics.
iprange Manage IP range.
ipranges Manage IP ranges.
maas Manage the MAAS server.
network Manage a network.
networks Manage the networks.
node-script-results
MAAS.
package-repositories
MAAS.
pod Manage an individual pod.
Disks) on a machine.
MAAS.
sshkey Manage an SSH key.
MAAS.
sslkey Manage an SSL key.
space Manage space.
spaces Manage spaces.
subnet Manage subnet.
subnets Manage subnets.
nodes.
user Manage a user account.
zone Manage a physical zone.
zones Manage physical zones.
Configuration
- Setting upstream DNS
- Importing an SSH key for your admin user
- Importing images
- Configuring DNS
Setting DNS
Importing images
grub-efi-signed/uefi amd64/generic
grub-efi/uefi arm64/generic
pxelinux/pxe i386/generic
ubuntu/bionic amd64/ga-18.04
ubuntu/bionic amd64/ga-18.04-lowlatency
ubuntu/bionic amd64/hwe-18.04
ubuntu/bionic amd64/hwe-18.04-edge
ubuntu/bionic amd64/hwe-18.04-lowlatency
ubuntu/bionic amd64/hwe-18.04-lowlatency-edge
"os": "ubuntu",
"release": "trusty",
"arches": [
"amd64"
"subarches": [
"labels": [
"boot_source_id": 1,
"id": 2,
Enabling DHCP
"fabric_id": $FABRIC_ID,
$RACK_CONTR_HOSTNAME
"subnet": {
"name": "192.168.123.0/24",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"external_dhcp": null,
"relay_vlan": null,
"fabric": "fabric-2",
"primary_rack": null,
"name": "untagged",
"id": 5003,
"space": "undefined",
"secondary_rack": null,
"fabric_id": 2,
"cidr": "192.168.123.0/24",
"rdns_mode": 2,
"gateway_ip": null,
"dns_servers": [],
"allow_dns": true,
"allow_proxy": true,
"active_discovery": false,
"managed": true,
"id": 4,
"type": "dynamic",
"end_ip": "192.168.123.253",
"user": {
"is_superuser": true,
"username": "admin",
"email": "admin@admin.com",
"is_local": true,
"comment": "",
"id": 1,
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"primary_rack": "8dwnne",
"name": "untagged",
"fabric_id": 2,
"id": 5003,
- subnet has the traditional meaning: a range of IP addresses covering a subset of IP addresses. Generally speaking , a subnet is a collection of IP addresses which includes at least two addresses.
- a space is a collection of subnets that you can create with MAAS, understanding that each subnet can belong to only one space. Spaces allow multiple subnets to communicate without requiring a direct network path between them.
- a zone is also an ad-hoc collection, but one which groups individual nodes, rather than subnets. MAAS allows you to create and edit zones at will.
- a fabric is essentially a collection of trunked switches, allowing you to access a group of VLANs.
VM hosts
It’s easy to add a LXD VM host: click the “Add KVM” button on the “KVM” page of the web UI, give the VM host a name, and select “lxd” as the VM host type. You will also need to enter the IP address for the gateway (.1) of the bridge you’re using to connect to LXD. The password will be the trust password you created when initializing LXD.
After you create a VM host, you compose hardware by selecting the host, and then selecting “Compose” from the Action menu. You can configure composed hardware as desired, including the number of cores, CPU speed, RAM and combined storage. Then just click “Compose machine”, and MAAS will combine resources to create a new, single entity that can be used just like any other machine. VM hosts abstact multiple resources into pools of composable hardware.
