This document explains resource-pool management tasks you can perform with the MAAS CLI.
- How can I create a resource pool?
- How can I list available resource pools?
- How can I list a single resource pool?
- How can I update a resource pool?
- How can I delete a resource pool?
- How can I add a machine to a resource pool?
- How can I get started with MAAS CLI?
- What do I need to know about resource pools?
Creating a resource pool
List available resource pools
List a single resource pool
Update a resource pool
Delete a resource pool
