Physical
Virtual
Output:
"id": 10,
"serial": "",
"block_size": 4096,
"available_size": 0,
"filesystem": null,
"id_path": "/dev/vda",
"size": 5368709120,
"model": "",
"type": "physical",
"uuid": null,
"used_size": 5365563392,
"partitions": [
"bootable": false,
"id": 9,
"size": 5360320512,
"type": "partition",
"filesystem": {
"mount_options": null,
"label": null,
"fstype": "lvm-pv",
"mount_point": null
"tags": [
"rotary"
"name": "vda"
"id": 11,
"serial": null,
"block_size": 4096,
"filesystem": {
"label": "root",
"fstype": "ext4",
"mount_point": "/"
"id_path": null,
"size": 3221225472,
"partition_table_type": null,
"model": null,
"type": "virtual",
"used_size": 3221225472,
"partitions": [],
"tags": [],
"name": "vgroot-lvroot"
"name": "vgroot-lvroot",
"type": "virtual",
"filesystem": {
"mount_point": "/",
"fstype": "ext4",
"label": "root"
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
"name": "vdb",
"used_for": "Unused",
"type": "physical",
"used_size": 0,
"filesystem": null,
"id_path": "",
"id": 12,
"block_size": 4096,
"tags": [],
"uuid": null,
"serial": "QM00001",
"partitions": [],
"size": 21474836480,
"model": "QEMU"
"block_size": 4096,
"filesystem": null,
"model": "QEMU",
"name": "newroot",
"partitions": [],
"tags": [],
"used_size": 0,
"id_path": "",
"uuid": null,
"id": 12,
"type": "physical",
"serial": "QM00001"
"block_size": 4096,
"size": 3221225472,
"filesystem": {
"label": "",
"fstype": "ext4",
"mount_point": null
"model": null,
"partitions": [],
"tags": [],
"id_path": null,
"id": 11,
"type": "virtual",
"serial": null
"available_size": 3221225472,
"type": "virtual",
"used_size": 0,
"filesystem": null,
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
"type": "virtual",
"filesystem": {
"mount_point": "/srv",
"mount_options": "",
"fstype": "ext4",
"label": ""
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
"type": "virtual",
"filesystem": {
"mount_point": null,
"fstype": "ext4",
"label": ""
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
