2.7 | 2.8 | 2.9 | 3.0 | |
Six questions you may have:
- How do I list availability zones?
- How do I add an availability zone?
- How do I edit an existing availability zone?
- How do I delete an existing availability zone?
- How do I assign a machine to an availability zone?
- How do I allocate a machine in a particular zone?
List availability zones
To see a list of availability zones, enter the following command:
maas $PROFILE zones read \
| jq -r '(["ZONE","NAME","DESCRIPTION"]
| (., map(length*"-"))), (.[] | [.id, .name, .description])
| @tsv' | column -t
which produces output similar to:
ZONE NAME DESCRIPTION
5 BizOffice
1 default
4 Inventory
2 Medications
3 Payroll
6 ProServ
Add a zone
To create a zone, enter the following command:
maas $PROFILE zones create name=$ZONE_NAME description=$ZONE_DESCRIPTION
Edit a zone
To edit a zone, enter a command similar to the following:
maas $PROFILE zone update $OLD_ZONE_NAME name=$NEW_ZONE_NAME \
Delete a zone
To delete a zone, enter a command like this:
maas $PROFILE zone delete $ZONE_NAME
Assign a machine to a zone
To assign a machine to a zone, first retrieve the machine’s system ID like this:
maas PROFILE machines read | jq '.[] | .hostname, .system_id'
Then enter the following command, using the system ID you just retrieved:
maas admin machine update $SYSTEM_ID zone=$ZONE_NAME
Allocate a machine in a zone
To deploy in a particular zone, call the acquire
method in the region-controller API <region-controller-api> as before, but pass the zone
parameter with the name of the zone. This method will allocate a machine in that zone, or fail with an HTTP 409 (“conflict”) error if the zone has no machines available that match your request.
Alternatively, you may want to request a machine that is not in a particular zone or one that is not in any of several zones. To do that, specify the not_in_zone
parameter to acquire
. This parameter takes a list of zone names; the allocated machine will not be in any of them. Again, if that leaves no machines available that match your request, the call will return a “conflict” error.
It is possible, though not usually useful, to combine the zone
and not_in_zone
parameters. If your choice for zone
is also present in not_in_zone
, no machine will ever match your request. Or if it’s not, then the not_in_zone
values will not affect the result of the call at all.
