API authentication reference
The MAAS API uses OAuth as its authentication mechanism. This isn’t third-party (3-legged) OAuth, so the process used is what’s commonly referred to as 0-legged OAuth: the consumer accesses protected resources by submitting OAuth signed requests.
Note that some API endpoints support unauthenticated requests (i.e. anonymous access). This article will help you learn:
Here are two examples on how to perform an authenticated GET request to retrieve the list of nodes. The <consumer_key>, <consumer_token>, <secret> tokens are the three elements that compose the API key (API key = ‘<consumer_key>:<consumer_token>:<secret>’).
How to perform authenticated requests in Python
Note: the below example uses fades, but you can also install the requests_oauthlib (pypi link) and oauthlib (pypi link) packages with pip. Replace <MAAS_SERVER_IP> with your server’s IP address, and <API-KEY> with your API key.
from oauthlib.oauth1 import SIGNATURE_PLAINTEXT # fades
from requests_oauthlib import OAuth1Session # fades
MAAS_HOST = "http://<MAAS_SERVER_IP>:5240/MAAS"
CONSUMER_KEY, CONSUMER_TOKEN, SECRET = "<API-KEY>".split(":")
maas = OAuth1Session(CONSUMER_KEY, resource_owner_key=CONSUMER_TOKEN, resource_owner_secret=SECRET, signature_method=SIGNATURE_PLAINTEXT)
nodes = maas.get(f"{MAAS_HOST}/api/2.0/machines/", params={"op": "list_allocated"})
nodes.raise_for_status()
print(nodes.json())
How to perform authenticated requests in Ruby
require 'oauth'
require 'oauth/signature/plaintext'
def perform_API_request(site, uri, key, secret, consumer_key)
    consumer = OAuth::Consumer.new(
        consumer_key, ",
        { :site => "http://localhost:5240/MAAS/api/2.0",
          :scheme => :header, :signature_method => "PLAINTEXT"})
    access_token = OAuth::AccessToken.new(consumer, key, secret)
    return access_token.request(:get, "/nodes/?op=list")
end
# API key = "<consumer_key>:<key>:<secret>"
response = perform_API_request(
     "http://server:5240/MAAS/api/2.0", "/nodes/?op=list", "<key>", "<secret>",
     "consumer_key>")
How to perform authenticated requests using cURL
curl --header "Authorization: OAuth oauth_version=1.0, oauth_signature_method=PLAINTEXT, oauth_consumer_key=$API_KEY[1], oauth_token=$API_KEY[2], oauth_signature=&$API_KEY[3], oauth_nonce=$(uuidgen), oauth_timestamp=$(date +%s)" \
$MAAS_URL/MAAS/api/2.0/users/
How to perform authenticated requests using HTTPie and fish
set API_KEY (string split : $API_KEY)
http $MAAS_URL/api/2.0/users/ \
Authorization:"OAuth oauth_version=1.0, oauth_signature_method=PLAINTEXT, oauth_consumer_key=$API_KEY[1], oauth_token=$API_KEY[2], oauth_signature=&$API_KEY[3], oauth_nonce=$(uuidgen), oauth_timestamp=$(date +%s)"
This Python example does not seem to work in Python 3.
[nix-shell:~/maas-oauth]$ ./test.py
  File "/Users/jpparker/maas-oauth/./test.py", line 3, in <module>
    import oauth.oauth as oauth
  File "/nix/store/9bl1s62q3l3ndzci6681mh4v02gm6rnz-python3-3.9.10-env/lib/python3.9/site-packages/oauth/oauth.py", line 29, in <module>
    import urlparse
ModuleNotFoundError: No module named 'urlparse'
The “oauth” library used in the example last had a release in 2009. This was already reported (Working python oauth example) but it doesn’t look to have been fixed.
We updated this last year, it seems to ahve reverted. I will find out why.
@billwear for some reason, revision 8 was reverted. That revision had changes made by @sparkiegeek that moved away from the deprecated library and was in a working state. Can we please bring back that version? Not sure what happened.
In the meantime, this should work:
import httplib2
import uuid
def perform_API_request(site, uri, method, key, secret, consumer_key):
    resource_tok_string = "oauth_token_secret=%s&oauth_token=%s" % (
        secret, key)
    resource_token = oauth.OAuthToken.from_string(resource_tok_string)
    consumer_token = oauth.OAuthConsumer(consumer_key, "")
    oauth_request = oauth.OAuthRequest.from_consumer_and_token(
        consumer_token, token=resource_token, http_url=site,
        parameters={'oauth_nonce': uuid.uuid4().hex})
    oauth_request.sign_request(
        oauth.OAuthSignatureMethod_PLAINTEXT(), consumer_token,
        resource_token)
    headers = oauth_request.to_header()
    url = "%s%s" % (site, uri)
    http = httplib2.Http()
    return http.request(url, method, body=None, headers=headers)
# API key = '<consumer_key>:<key>:<secret>'
    'http://server/MAAS/api/1.0', '/nodes/?op=list', 'GET', '<key>', '<secret>',
    '<consumer_key>')
yep, accidental regression. will fix today.
should be done. lmk if it’s not right.
You can also make an API call with cURL or HTTPie.
To do this you need to manually craft a proper Authorization header.
Here is an example using fish and HTTPie:
With cURL it will be as simple as:
