Hello, MAAS users! We are pleased to announce the release of the MAAS 2.9 Beta 3.
You can install the Debian packages from the MAAS 2.9 PPA:
sudo add-apt-repository ppa:maas/2.9
sudo apt-get update
sudo apt-get -y install maas
Or install the Snap with
sudo snap install --channel=2.9/beta maas
You can read the release notes and comment on the Beta there. Please be sure to file any bugs you may find.
