Add machines (2.8/UI)
Standard 2.7/UI 2.8/UI CLI-only
How enlistment works
Add a machine manually
The fields on the “Add machine” screen are as follows:
  • Machine name: This field is used to identify the machine to the user. It can be set to anything, though it is often set to the MAC address of the machine in question. This field is optional, in that MAAS will assign a unique, nonsense name if you leave it blank. You can change this nonsense name later, if desired.
  • Domain: This field sets the domain name of the domain managed by MAAS. It can be set to anything; MAAS assigns the domain name “maas” by default.
  • Architecture: This field refers to the architecture of the machine being added.
  • Minimum Kernal: This field supplies a dropdown of possible kernels available for deployment on this machine.
  • Zone: This field allows you to set the availability zone, selected from AZs that you have already created (if any).
  • Resource pool: This field allows you to set the resource pool for this machine, selected from pools you have already created (if any).
  • MAC Address: You should fill in this field with the MAC address of the machine you are adding. Note that the MAC address entered here must use a colon (":") separator, although some MAC addresses are written with dash ("-") separators.
  • Power type: You must select the power type supported by the machine you are adding, and fill in additional required fields that appear. See Power management for details on the availabile power types and the relevant parameters for each type.
Normally, when you add a machine manually, MAAS will immediately attempt to commission the machine. Note that you will need to configure the underlying machine to boot over the network, or commissioning will fail. MAAS cannot handle this configuration for you. While the correct method for configuring network boot depends heavily on your server, there are a couple of common elements:
  • The network card on your server must be able to support PXE, i.e., your NIC – whether independent or integrated on a motherboard – must have a boot PROM that supports network booting. You’ll need to consult the documentation for the machine in question to determine this.
  • You usually have to interrupt the boot process and enter the BIOS/UEFI menu to configure the network cards’s PXE stack. Again, you may need to consult your machine’s documentation to pin down this step.
BMC enlistment
IPMI machines
Non-IPMI machines
Add a machine via a chassis
Use the chassis feature to add multiple machines at once. To do this, instead of selecting ‘Machine’ as above, choose ‘Chassis’ from the drop-down menu. In the following example, MAAS will add all available VMs from the given virsh address:
