About MAAS networks
There are elements of MAAS networking that are unique to the product. This section will help you learn:
About network discovery
MAAS constantly listens to the network and reports any discovered devices. Devices are identified when the rack controller observes them communicating on an attached IPv4 subnet. Discovered devices that do not correspond to machines and devices already known to MAAS are shown on the dashboard. If a device advertises a hostname using mDNS (such as with avahi or Bonjour), MAAS will also present the discovered hostname in the Dashboard.
Using the Dashboard, an unknown discovered device can be added to MAAS as a device or as a network interface belonging to a machine or device. Clicking the down arrow to the right of a new device allows values such as âTypeâ, âDomainâ, âIP Assignmentâ and âParentâ to be changed prior to the device being added. Selecting a Parent device is optional.
About subnet management
Fabrics, VLANs, and spaces do not require much configuration beyond names and descriptions. You can change the MTU for a VLAN, as well as enable DHCP. None of these options requires detailed instruction.
A subnet, on the other hand, provides a number of configuration options relevant to the day-to-day operation of MAAS. By default, MAAS manages subnets in your configuration, but this is easily changed.
When a subnet is managed, MAAS handles all aspects of IP address allocation. This process includes managing DHCP leases and assigned static addresses. Typically MAAS would have one managed subnet, with any additional subnets unmanaged. This arrangement allows for more control over which subnet gets used for DHCP. Additionally, as detailed below, an unmanaged subnet treats reserved IP ranges differently, in a way that some administrators find more intuitive.
About managed subnets
- Lease addresses for DHCP from a reserved dynamic IP range
- Assign static addresses not included in a reserved IP range, typically via âAuto assignâ IP allocation mode for a node.
If needed, you can also define a static route between two subnets. A static route is defined on a per-subnet basis to use a particular gateway, using a configured destination.
About unmanaged subnets
When management is disabled for a subnet, the definition of a reserved IP range differs from the managed mode. Here, a reserved IP range tells MAAS to only allocate addresses from this range (via âAuto assignâ). Also, DHCP will never lease addresses from an unmanaged subnet.
About IP address tracking
When you enable IP address tracking, MAAS will keep track of all assigned addresses, regardless of whether they come from managed or unmanaged subnets.
About IPv6
Support for IPv6 in MAAS is similar to support for IPv4. This subsection will help you learn:
A rack controller in an IPv6 context needs to have the region API server URL specified with brackets:
http://[::1]:5240/MAAS/
About enabling IPv6
You enable IPv6 networking in the same way that you enable IPv4 networking: configure a separate rack controller interface for your IPv6 subnet. The IPv6 interface must define a static address range. Provided that you already have a functioning IPv6 network, thatâs all there is to it. The following sections explain requirements, supported operations, and what to do if you donât yet have a functioning IPv6 network.
An IPv6 interface can use the same network interface on the rack controller as an existing IPv4 network interface. It just defines a different subnet, with IPv6 addressing. A machine thatâs connected to the IPv4 subnet also connected to the IPv6 subnet on the same network segment.
About IPv6 subnets
If you define a reserved static IP range, then machines deployed on the subnet will get a static address in this range. Since IPv6 networks usually are 64 bits wide, you can be generous with the range size. You can typically leave the netmask and broadcast address fields blank.
You may want MAAS to manage DHCP and DNS, but itâs not required. Machines do not need a DHCP server at all for IPv6; MAAS configures static IPv6 addresses on a machineâs network interface while deploying it. A DHCPv6 server can provide addresses for containers or virtual machines running on the machines, as well as devices on the network that are not managed by MAAS. The machines do not need DHCPv6. MAAS will not be aware of any addresses issued by DHCP, and cannot guarantee that they will stay unchanged.
About IPV6 routing
- Switches that allow stateless configuration of their unique IP addresses, based on MAC addresses.
- Switches that enable them to request stateless configuration from a DHCP server.
- Switches that In any allow them to request a stateful IP address from a DHCP server.
However, when MAAS configures IPv6 networking on a machine, it does not rely on RAs. It statically configures a machineâs default IPv6 route to use the router that is set on the cluster interface, so that the machine will know their default gateway. They do not need DHCP and will not autoconfigure global addresses.
If you need RAs, but your gateway does not send them, you could install and configure radvd somewhere on the network to advertise its route.
About availability zones
This subsection explains some characteristics and uses of availability zones. Here you have the opportunity to learn:
About fault tolerance
Fault tolerance is âthe property that enables a system to continue operating properly in the event of the failure of (or one or more faults within) some of its componentsâ. To help create better fault tolerance, multiple MAAS zones can be employed.
About service performance
About power management
Nodes can be distributed in such a way that power-hungry and/or âhotâ systems are located in different zones. This can help mitigate power consumption and heat problems.
thank you! let me know if the fix is good.
