Hello MAASters!
We are happy to announce MAAS 2.6.0beta2. This release introduces new and exciting features and UI improvements.
New features & improvements
UI - add group by
The machine listing page has now the ability to group machine differently:
- Group by status - Machines will be grouped accordingly to their status
- Group by user - Machines will be grouped by the owned user.
- No grouping - allows the same older view.
Bug fixes
For other issues or bugs fixed in this release, please refer to:
| Bug # | Description |
| LP: #1821220 | Base VMware ESXi partition should not be removable |
| LP: #1822173 | [2.6a2, UI] In table actions - deploying doesn’t pick default os/release |
| LP: #1826272 | [2.5, 2.6, UI, regression] The UI doesn’t allow you to undercommit resources in a pod |
| LP: #1822525 | [UI] AZ edit: Cannot read property ‘classList’ of null |
| LP: #1824883 | [UI]Register KVM host warning not clear |
| LP: #1825143 | [UI] Default deploy os/release not shown in in-table machine action |
| LP: #1825240 | Do not allow datastores to be created when the VMFS6 root layout is not present |
| LP: #1825241 | Unable to set root storage device with VMFS6 layout |
| LP: #1825244 | Websocket should send whether or not the VMFS6 layout was applied |
| LP: #1826600 | [2.6] Can’t force the deletion of a KVM host on release |
https://launchpad.net/maas/+milestone/2.6.0beta2
Availability
MAAS 2.6.0~beta2 is available in the following PPA:
sudo apt install maas
