Hello everyone
I am trying to deploy MAAS for testing purposes and I can see that the ethernet device that has PXE checked mark is on a virtual interface used for one of my containers instead of the physical ethernet device (eno1). Is there any option to change it from virtual to eno1?
Thank you
Hey,
If you have PXE set on that interface it means that the machine actually PXE booted from that MAC address.
There is no way to change that, unless you actually boot the machine from another port/MAC address
Another thing is that for the default subnet I haven’t set DHCP as it is given by my internet router. Vor the VLANs everything is set accordingly
Did you setup your internet router accordingly to integrate with MAAS? If not, see Show and Tell: Using external DHCP with MAAS
Thank you for the tip. Enabling DHCP for default vlan (192.168.1.0/24) solved the issue.
Although the commissioning was partial not total I have the OS in place on machines.
