Here are the relevant logs (scrubbed as best I could scrub em):
cloud-init.log
2019-06-12 00:41:52,411 - util.py[DEBUG]: Cloud-init v. 19.1-1-gbaa47854-0ubuntu1~16.04.1 running 'init-local' at Wed, 12 Jun 2019 00:41:52 +0000. Up 10.22 seconds.
2019-06-12 00:41:52,411 - main.py[DEBUG]: No kernel command line url found.
2019-06-12 00:41:52,411 - main.py[DEBUG]: Closing stdin.
2019-06-12 00:41:52,414 - util.py[DEBUG]: Writing to /var/log/cloud-init.log - ab: [644] 0 bytes
2019-06-12 00:41:52,415 - util.py[DEBUG]: Changing the ownership of /var/log/cloud-init.log to 104:4
2019-06-12 00:41:52,415 - main.py[DEBUG]: manual cache clean set from config
2019-06-12 00:41:52,415 - util.py[DEBUG]: Attempting to remove /var/lib/cloud/instance/boot-finished
2019-06-12 00:41:52,415 - util.py[DEBUG]: Attempting to remove /var/lib/cloud/data/no-net
2019-06-12 00:41:52,416 - handlers.py[DEBUG]: start: init-local/check-cache: attempting to read from cache [trust]
2019-06-12 00:41:52,429 - handlers.py[WARNING]: failed posting event: start: init-local/check-cache: attempting to read from cache [trust]
2019-06-12 00:41:52,429 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/obj.pkl (quiet=False)
2019-06-12 00:41:52,429 - stages.py[DEBUG]: no cache found
2019-06-12 00:41:52,429 - handlers.py[DEBUG]: finish: init-local/check-cache: SUCCESS: no cache found
2019-06-12 00:41:52,430 - handlers.py[WARNING]: failed posting event: finish: init-local/check-cache: SUCCESS: no cache found
2019-06-12 00:41:52,430 - util.py[DEBUG]: Attempting to remove /var/lib/cloud/instance
2019-06-12 00:41:52,433 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2019-06-12 00:41:52,433 - __init__.py[DEBUG]: Looking for data source in: ['MAAS'], via packages ['', 'cloudinit.sources'] that matches dependencies ['FILESYSTEM']
2019-06-12 00:41:52,434 - __init__.py[DEBUG]: Searching for local data source in: []
2019-06-12 00:41:52,434 - main.py[DEBUG]: No local datasource found
2019-06-12 00:41:52,434 - stages.py[DEBUG]: applying net config names for {'config': [{'id': 'eno1', 'mtu': 1500, 'type': 'physical', 'subnets': [{'type': 'manual'}], 'name': 'eno1', 'mac_address': '2c:60:0c:83:6c:f3'}, {'id': 'eno2', 'mtu': 1500, 'type': 'physical', 'subnets': [{'address': 'xxx.xxx.xxx.xxx/24', 'dns_search': ['maas'], 'dns_nameservers': ['8.8.8.8'], 'type': 'static', 'gateway': 'xxx.xxx.xxx.xxx'}], 'name': 'eno2', 'mac_address': '2c:60:0c:83:6c:f4'}, {'id': 'enp6s0f0', 'mtu': 1500, 'type': 'physical', 'subnets': [{'type': 'manual'}], 'name': 'enp6s0f0', 'mac_address': '90:e2:ba:7e:c4:c0'}, {'id': 'enp6s0f1', 'mtu': 1500, 'type': 'physical', 'subnets': [{'type': 'manual'}], 'name': 'enp6s0f1', 'mac_address': '90:e2:ba:7e:c4:c1'}, {'address': ['8.8.8.8'], 'search': ['maas'], 'type': 'nameserver'}], 'version': 1}
2019-06-12 00:41:52,434 - util.py[DEBUG]: Reading from /sys/class/net/eno1/device/device (quiet=False)
2019-06-12 00:41:52,434 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/eno1/device/device
2019-06-12 00:41:52,435 - util.py[DEBUG]: Reading from /sys/class/net/eno2/device/device (quiet=False)
2019-06-12 00:41:52,435 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/eno2/device/device
2019-06-12 00:41:52,435 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/device/device (quiet=False)
2019-06-12 00:41:52,435 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/enp6s0f0/device/device
2019-06-12 00:41:52,435 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/device/device (quiet=False)
2019-06-12 00:41:52,435 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/enp6s0f1/device/device
2019-06-12 00:41:52,435 - util.py[DEBUG]: Reading from /sys/class/net/lo/addr_assign_type (quiet=False)
2019-06-12 00:41:52,435 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/lo/addr_assign_type
2019-06-12 00:41:52,435 - util.py[DEBUG]: Reading from /sys/class/net/lo/uevent (quiet=False)
2019-06-12 00:41:52,435 - util.py[DEBUG]: Read 23 bytes from /sys/class/net/lo/uevent
2019-06-12 00:41:52,435 - util.py[DEBUG]: Reading from /sys/class/net/lo/address (quiet=False)
2019-06-12 00:41:52,435 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/lo/address
2019-06-12 00:41:52,435 - util.py[DEBUG]: Reading from /sys/class/net/lo/device/device (quiet=False)
2019-06-12 00:41:52,435 - util.py[DEBUG]: Reading from /sys/class/net/eno2/addr_assign_type (quiet=False)
2019-06-12 00:41:52,436 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/eno2/addr_assign_type
2019-06-12 00:41:52,436 - util.py[DEBUG]: Reading from /sys/class/net/eno2/uevent (quiet=False)
2019-06-12 00:41:52,436 - util.py[DEBUG]: Read 25 bytes from /sys/class/net/eno2/uevent
2019-06-12 00:41:52,436 - util.py[DEBUG]: Reading from /sys/class/net/eno2/address (quiet=False)
2019-06-12 00:41:52,436 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/eno2/address
2019-06-12 00:41:52,436 - util.py[DEBUG]: Reading from /sys/class/net/eno2/device/device (quiet=False)
2019-06-12 00:41:52,436 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/eno2/device/device
2019-06-12 00:41:52,436 - util.py[DEBUG]: Reading from /sys/class/net/eno1/addr_assign_type (quiet=False)
2019-06-12 00:41:52,436 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/eno1/addr_assign_type
2019-06-12 00:41:52,436 - util.py[DEBUG]: Reading from /sys/class/net/eno1/uevent (quiet=False)
2019-06-12 00:41:52,436 - util.py[DEBUG]: Read 25 bytes from /sys/class/net/eno1/uevent
2019-06-12 00:41:52,436 - util.py[DEBUG]: Reading from /sys/class/net/eno1/address (quiet=False)
2019-06-12 00:41:52,436 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/eno1/address
2019-06-12 00:41:52,436 - util.py[DEBUG]: Reading from /sys/class/net/eno1/device/device (quiet=False)
2019-06-12 00:41:52,436 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/eno1/device/device
2019-06-12 00:41:52,436 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/addr_assign_type (quiet=False)
2019-06-12 00:41:52,437 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/enp6s0f1/addr_assign_type
2019-06-12 00:41:52,437 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/uevent (quiet=False)
2019-06-12 00:41:52,437 - util.py[DEBUG]: Read 29 bytes from /sys/class/net/enp6s0f1/uevent
2019-06-12 00:41:52,437 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/address (quiet=False)
2019-06-12 00:41:52,437 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/enp6s0f1/address
2019-06-12 00:41:52,437 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/device/device (quiet=False)
2019-06-12 00:41:52,437 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/enp6s0f1/device/device
2019-06-12 00:41:52,437 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/addr_assign_type (quiet=False)
2019-06-12 00:41:52,437 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/enp6s0f0/addr_assign_type
2019-06-12 00:41:52,437 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/uevent (quiet=False)
2019-06-12 00:41:52,437 - util.py[DEBUG]: Read 29 bytes from /sys/class/net/enp6s0f0/uevent
2019-06-12 00:41:52,437 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/address (quiet=False)
2019-06-12 00:41:52,437 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/enp6s0f0/address
2019-06-12 00:41:52,437 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/device/device (quiet=False)
2019-06-12 00:41:52,437 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/enp6s0f0/device/device
2019-06-12 00:41:52,438 - util.py[DEBUG]: Reading from /sys/class/net/lo/operstate (quiet=False)
2019-06-12 00:41:52,438 - util.py[DEBUG]: Read 8 bytes from /sys/class/net/lo/operstate
2019-06-12 00:41:52,438 - util.py[DEBUG]: Reading from /sys/class/net/eno2/operstate (quiet=False)
2019-06-12 00:41:52,438 - util.py[DEBUG]: Read 5 bytes from /sys/class/net/eno2/operstate
2019-06-12 00:41:52,438 - util.py[DEBUG]: Reading from /sys/class/net/eno1/operstate (quiet=False)
2019-06-12 00:41:52,438 - util.py[DEBUG]: Read 5 bytes from /sys/class/net/eno1/operstate
2019-06-12 00:41:52,438 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/operstate (quiet=False)
2019-06-12 00:41:52,438 - util.py[DEBUG]: Read 5 bytes from /sys/class/net/enp6s0f1/operstate
2019-06-12 00:41:52,438 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/operstate (quiet=False)
2019-06-12 00:41:52,438 - util.py[DEBUG]: Read 5 bytes from /sys/class/net/enp6s0f0/operstate
2019-06-12 00:41:52,438 - util.py[DEBUG]: Running command ['ip', '-6', 'addr', 'show', 'permanent', 'scope', 'global'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:52,487 - util.py[DEBUG]: Running command ['ip', '-4', 'addr', 'show'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:52,495 - __init__.py[DEBUG]: no work necessary for renaming of [['2c:60:0c:83:6c:f3', 'eno1', 'igb', '0x1521'], ['2c:60:0c:83:6c:f4', 'eno2', 'igb', '0x1521'], ['90:e2:ba:7e:c4:c0', 'enp6s0f0', 'ixgbe', '0x10fb'], ['90:e2:ba:7e:c4:c1', 'enp6s0f1', 'ixgbe', '0x10fb']]
2019-06-12 00:41:52,496 - stages.py[INFO]: Applying network configuration from system_cfg bringup=False: {'config': [{'id': 'eno1', 'mtu': 1500, 'type': 'physical', 'subnets': [{'type': 'manual'}], 'name': 'eno1', 'mac_address': '2c:60:0c:83:6c:f3'}, {'id': 'eno2', 'mtu': 1500, 'type': 'physical', 'subnets': [{'address': 'xxx.xxx.xxx.xxx/24', 'dns_search': ['maas'], 'dns_nameservers': ['8.8.8.8'], 'type': 'static', 'gateway': 'xxx.xxx.xxx.xxx'}], 'name': 'eno2', 'mac_address': '2c:60:0c:83:6c:f4'}, {'id': 'enp6s0f0', 'mtu': 1500, 'type': 'physical', 'subnets': [{'type': 'manual'}], 'name': 'enp6s0f0', 'mac_address': '90:e2:ba:7e:c4:c0'}, {'id': 'enp6s0f1', 'mtu': 1500, 'type': 'physical', 'subnets': [{'type': 'manual'}], 'name': 'enp6s0f1', 'mac_address': '90:e2:ba:7e:c4:c1'}, {'address': ['8.8.8.8'], 'search': ['maas'], 'type': 'nameserver'}], 'version': 1}
2019-06-12 00:41:52,496 - __init__.py[DEBUG]: Selected renderer 'eni' from priority list: None
2019-06-12 00:41:52,517 - util.py[DEBUG]: Writing to /etc/network/interfaces.d/50-cloud-init.cfg - wb: [644] 690 bytes
2019-06-12 00:41:52,518 - util.py[DEBUG]: Writing to /etc/udev/rules.d/70-persistent-net.rules - wb: [644] 392 bytes
2019-06-12 00:41:52,518 - main.py[DEBUG]: [local] Exiting without datasource
2019-06-12 00:41:52,546 - util.py[DEBUG]: Reading from /proc/uptime (quiet=False)
2019-06-12 00:41:52,546 - util.py[DEBUG]: Read 13 bytes from /proc/uptime
2019-06-12 00:41:52,546 - util.py[DEBUG]: cloud-init mode 'init' took 0.172 seconds (0.18)
2019-06-12 00:41:52,546 - handlers.py[DEBUG]: finish: init-local: SUCCESS: searching for local datasources
2019-06-12 00:41:52,548 - handlers.py[WARNING]: failed posting event: finish: init-local: SUCCESS: searching for local datasources
2019-06-12 00:41:53,758 - util.py[DEBUG]: Cloud-init v. 19.1-1-gbaa47854-0ubuntu1~16.04.1 running 'init' at Wed, 12 Jun 2019 00:41:53 +0000. Up 11.57 seconds.
2019-06-12 00:41:53,758 - main.py[DEBUG]: No kernel command line url found.
2019-06-12 00:41:53,759 - main.py[DEBUG]: Closing stdin.
2019-06-12 00:41:53,761 - util.py[DEBUG]: Writing to /var/log/cloud-init.log - ab: [644] 0 bytes
2019-06-12 00:41:53,761 - util.py[DEBUG]: Changing the ownership of /var/log/cloud-init.log to 104:4
2019-06-12 00:41:53,762 - util.py[DEBUG]: Running command ['ip', 'addr', 'show'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:53,765 - util.py[DEBUG]: Running command ['ip', '-o', 'route', 'list'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:53,766 - util.py[DEBUG]: Running command ['ip', '--oneline', '-6', 'route', 'list', 'table', 'all'] with allowed return codes [0, 1] (shell=False, capture=True)
2019-06-12 00:41:53,769 - main.py[DEBUG]: Checking to see if files that we need already exist from a previous run that would allow us to stop early.
2019-06-12 00:41:53,769 - main.py[DEBUG]: Execution continuing, no previous run detected that would allow us to stop early.
2019-06-12 00:41:53,780 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:53,780 - handlers.py[DEBUG]: start: init-network/check-cache: attempting to read from cache [trust]
2019-06-12 00:41:53,780 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/obj.pkl (quiet=False)
2019-06-12 00:41:53,780 - stages.py[DEBUG]: no cache found
2019-06-12 00:41:53,790 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:53,790 - handlers.py[DEBUG]: finish: init-network/check-cache: SUCCESS: no cache found
2019-06-12 00:41:53,790 - util.py[DEBUG]: Attempting to remove /var/lib/cloud/instance
2019-06-12 00:41:53,792 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2019-06-12 00:41:53,792 - __init__.py[DEBUG]: Looking for data source in: ['MAAS'], via packages ['', 'cloudinit.sources'] that matches dependencies ['FILESYSTEM', 'NETWORK']
2019-06-12 00:41:53,793 - __init__.py[DEBUG]: Searching for network data source in: ['DataSourceMAAS']
2019-06-12 00:41:53,796 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:53,796 - handlers.py[DEBUG]: start: init-network/search-MAAS: searching for network data from DataSourceMAAS
2019-06-12 00:41:53,796 - __init__.py[DEBUG]: Seeing if we can get any data from <class 'cloudinit.sources.DataSourceMAAS.DataSourceMAAS'>
2019-06-12 00:41:53,796 - __init__.py[DEBUG]: Update datasource metadata and network config due to events: New instance first boot
2019-06-12 00:41:53,830 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/2012-03-01/meta-data/instance-id (200, 6b) after 1 attempts
2019-06-12 00:41:53,830 - DataSourceMAAS.py[DEBUG]: Using metadata source: 'http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/2012-03-01/meta-data/instance-id'
2019-06-12 00:41:53,872 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/2012-03-01/meta-data/instance-id (200, 6b) after 1 attempts
2019-06-12 00:41:53,922 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/2012-03-01/meta-data/local-hostname (200, 12b) after 1 attempts
2019-06-12 00:41:53,955 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/2012-03-01/meta-data/public-keys (200, 380b) after 1 attempts
2019-06-12 00:41:54,014 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/2012-03-01/meta-data/vendor-data (200, 78b) after 1 attempts
2019-06-12 00:41:54,080 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/2012-03-01/user-data (200, 912b) after 1 attempts
2019-06-12 00:41:54,081 - util.py[DEBUG]: Attempting to load yaml from string of length 78 with allowed root types <class 'object'>
2019-06-12 00:41:54,084 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,085 - handlers.py[DEBUG]: finish: init-network/search-MAAS: SUCCESS: found network data from DataSourceMAAS
2019-06-12 00:41:54,085 - stages.py[INFO]: Loaded datasource DataSourceMAAS - DataSourceMAAS [http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/]
2019-06-12 00:41:54,085 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2019-06-12 00:41:54,085 - util.py[DEBUG]: Read 3612 bytes from /etc/cloud/cloud.cfg
2019-06-12 00:41:54,085 - util.py[DEBUG]: Attempting to load yaml from string of length 3612 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,097 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/curtin-preserve-sources.cfg (quiet=False)
2019-06-12 00:41:54,097 - util.py[DEBUG]: Read 35 bytes from /etc/cloud/cloud.cfg.d/curtin-preserve-sources.cfg
2019-06-12 00:41:54,097 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,098 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg_maas.cfg (quiet=False)
2019-06-12 00:41:54,098 - util.py[DEBUG]: Read 316 bytes from /etc/cloud/cloud.cfg.d/90_dpkg_maas.cfg
2019-06-12 00:41:54,098 - util.py[DEBUG]: Attempting to load yaml from string of length 316 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,099 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg_local_cloud_config.cfg (quiet=False)
2019-06-12 00:41:54,099 - util.py[DEBUG]: Read 361 bytes from /etc/cloud/cloud.cfg.d/90_dpkg_local_cloud_config.cfg
2019-06-12 00:41:54,099 - util.py[DEBUG]: Attempting to load yaml from string of length 361 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,100 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2019-06-12 00:41:54,101 - util.py[DEBUG]: Read 81 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2019-06-12 00:41:54,101 - util.py[DEBUG]: Attempting to load yaml from string of length 81 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,101 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/50-curtin-networking.cfg (quiet=False)
2019-06-12 00:41:54,101 - util.py[DEBUG]: Read 762 bytes from /etc/cloud/cloud.cfg.d/50-curtin-networking.cfg
2019-06-12 00:41:54,101 - util.py[DEBUG]: Attempting to load yaml from string of length 762 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,106 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2019-06-12 00:41:54,106 - util.py[DEBUG]: Read 2057 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2019-06-12 00:41:54,106 - util.py[DEBUG]: Attempting to load yaml from string of length 2057 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,110 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2019-06-12 00:41:54,110 - util.py[DEBUG]: Read 45 bytes from /run/cloud-init/cloud.cfg
2019-06-12 00:41:54,110 - util.py[DEBUG]: Attempting to load yaml from string of length 45 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,110 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,111 - util.py[DEBUG]: loaded blob returned None, returning default.
2019-06-12 00:41:54,111 - util.py[DEBUG]: Attempting to remove /var/lib/cloud/instance
2019-06-12 00:41:54,111 - util.py[DEBUG]: Creating symbolic link from '/var/lib/cloud/instance' => '/var/lib/cloud/instances/re6cck'
2019-06-12 00:41:54,112 - util.py[DEBUG]: Reading from /var/lib/cloud/instances/re6cck/datasource (quiet=False)
2019-06-12 00:41:54,112 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/re6cck/datasource - wb: [644] 75 bytes
2019-06-12 00:41:54,113 - util.py[DEBUG]: Writing to /var/lib/cloud/data/previous-datasource - wb: [644] 75 bytes
2019-06-12 00:41:54,113 - util.py[DEBUG]: Reading from /var/lib/cloud/data/instance-id (quiet=False)
2019-06-12 00:41:54,113 - stages.py[DEBUG]: previous iid found to be NO_PREVIOUS_INSTANCE_ID
2019-06-12 00:41:54,113 - util.py[DEBUG]: Writing to /var/lib/cloud/data/instance-id - wb: [644] 7 bytes
2019-06-12 00:41:54,113 - util.py[DEBUG]: Writing to /run/cloud-init/.instance-id - wb: [644] 7 bytes
2019-06-12 00:41:54,114 - util.py[DEBUG]: Writing to /var/lib/cloud/data/previous-instance-id - wb: [644] 24 bytes
2019-06-12 00:41:54,114 - util.py[DEBUG]: Writing to /var/lib/cloud/instance/manual-clean - w: [644] 0 characters
2019-06-12 00:41:54,115 - util.py[DEBUG]: Writing to /var/lib/cloud/instance/obj.pkl - wb: [400] 9526 bytes
2019-06-12 00:41:54,115 - main.py[DEBUG]: [net] init will now be targeting instance id: re6cck. new=True
2019-06-12 00:41:54,115 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2019-06-12 00:41:54,116 - util.py[DEBUG]: Read 3612 bytes from /etc/cloud/cloud.cfg
2019-06-12 00:41:54,116 - util.py[DEBUG]: Attempting to load yaml from string of length 3612 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,127 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/curtin-preserve-sources.cfg (quiet=False)
2019-06-12 00:41:54,127 - util.py[DEBUG]: Read 35 bytes from /etc/cloud/cloud.cfg.d/curtin-preserve-sources.cfg
2019-06-12 00:41:54,127 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,128 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg_maas.cfg (quiet=False)
2019-06-12 00:41:54,128 - util.py[DEBUG]: Read 316 bytes from /etc/cloud/cloud.cfg.d/90_dpkg_maas.cfg
2019-06-12 00:41:54,128 - util.py[DEBUG]: Attempting to load yaml from string of length 316 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,129 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg_local_cloud_config.cfg (quiet=False)
2019-06-12 00:41:54,129 - util.py[DEBUG]: Read 361 bytes from /etc/cloud/cloud.cfg.d/90_dpkg_local_cloud_config.cfg
2019-06-12 00:41:54,129 - util.py[DEBUG]: Attempting to load yaml from string of length 361 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,131 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2019-06-12 00:41:54,131 - util.py[DEBUG]: Read 81 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2019-06-12 00:41:54,131 - util.py[DEBUG]: Attempting to load yaml from string of length 81 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,131 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/50-curtin-networking.cfg (quiet=False)
2019-06-12 00:41:54,131 - util.py[DEBUG]: Read 762 bytes from /etc/cloud/cloud.cfg.d/50-curtin-networking.cfg
2019-06-12 00:41:54,131 - util.py[DEBUG]: Attempting to load yaml from string of length 762 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,136 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2019-06-12 00:41:54,136 - util.py[DEBUG]: Read 2057 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2019-06-12 00:41:54,136 - util.py[DEBUG]: Attempting to load yaml from string of length 2057 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,140 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2019-06-12 00:41:54,140 - util.py[DEBUG]: Read 45 bytes from /run/cloud-init/cloud.cfg
2019-06-12 00:41:54,140 - util.py[DEBUG]: Attempting to load yaml from string of length 45 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,140 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,141 - util.py[DEBUG]: loaded blob returned None, returning default.
2019-06-12 00:41:54,142 - stages.py[DEBUG]: applying net config names for {'config': [{'name': 'eno1', 'mtu': 1500, 'subnets': [{'type': 'manual'}], 'type': 'physical', 'id': 'eno1', 'mac_address': '2c:60:0c:83:6c:f3'}, {'name': 'eno2', 'mtu': 1500, 'subnets': [{'gateway': '105.91.248.1', 'type': 'static', 'dns_nameservers': ['8.8.8.8'], 'address': '105.91.248.156/24', 'dns_search': ['maas']}], 'type': 'physical', 'id': 'eno2', 'mac_address': '2c:60:0c:83:6c:f4'}, {'name': 'enp6s0f0', 'mtu': 1500, 'subnets': [{'type': 'manual'}], 'type': 'physical', 'id': 'enp6s0f0', 'mac_address': '90:e2:ba:7e:c4:c0'}, {'name': 'enp6s0f1', 'mtu': 1500, 'subnets': [{'type': 'manual'}], 'type': 'physical', 'id': 'enp6s0f1', 'mac_address': '90:e2:ba:7e:c4:c1'}, {'search': ['maas'], 'type': 'nameserver', 'address': ['8.8.8.8']}], 'version': 1}
2019-06-12 00:41:54,142 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2019-06-12 00:41:54,143 - util.py[DEBUG]: Reading from /sys/class/net/eno1/device/device (quiet=False)
2019-06-12 00:41:54,143 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/eno1/device/device
2019-06-12 00:41:54,143 - util.py[DEBUG]: Reading from /sys/class/net/eno2/device/device (quiet=False)
2019-06-12 00:41:54,143 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/eno2/device/device
2019-06-12 00:41:54,143 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/device/device (quiet=False)
2019-06-12 00:41:54,143 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/enp6s0f0/device/device
2019-06-12 00:41:54,143 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/device/device (quiet=False)
2019-06-12 00:41:54,143 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/enp6s0f1/device/device
2019-06-12 00:41:54,143 - util.py[DEBUG]: Reading from /sys/class/net/lo/addr_assign_type (quiet=False)
2019-06-12 00:41:54,143 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/lo/addr_assign_type
2019-06-12 00:41:54,143 - util.py[DEBUG]: Reading from /sys/class/net/lo/uevent (quiet=False)
2019-06-12 00:41:54,143 - util.py[DEBUG]: Read 23 bytes from /sys/class/net/lo/uevent
2019-06-12 00:41:54,143 - util.py[DEBUG]: Reading from /sys/class/net/lo/address (quiet=False)
2019-06-12 00:41:54,143 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/lo/address
2019-06-12 00:41:54,144 - util.py[DEBUG]: Reading from /sys/class/net/lo/device/device (quiet=False)
2019-06-12 00:41:54,144 - util.py[DEBUG]: Reading from /sys/class/net/eno2/addr_assign_type (quiet=False)
2019-06-12 00:41:54,144 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/eno2/addr_assign_type
2019-06-12 00:41:54,144 - util.py[DEBUG]: Reading from /sys/class/net/eno2/uevent (quiet=False)
2019-06-12 00:41:54,144 - util.py[DEBUG]: Read 25 bytes from /sys/class/net/eno2/uevent
2019-06-12 00:41:54,144 - util.py[DEBUG]: Reading from /sys/class/net/eno2/address (quiet=False)
2019-06-12 00:41:54,144 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/eno2/address
2019-06-12 00:41:54,144 - util.py[DEBUG]: Reading from /sys/class/net/eno2/device/device (quiet=False)
2019-06-12 00:41:54,144 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/eno2/device/device
2019-06-12 00:41:54,144 - util.py[DEBUG]: Reading from /sys/class/net/eno1/addr_assign_type (quiet=False)
2019-06-12 00:41:54,144 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/eno1/addr_assign_type
2019-06-12 00:41:54,144 - util.py[DEBUG]: Reading from /sys/class/net/eno1/uevent (quiet=False)
2019-06-12 00:41:54,144 - util.py[DEBUG]: Read 25 bytes from /sys/class/net/eno1/uevent
2019-06-12 00:41:54,144 - util.py[DEBUG]: Reading from /sys/class/net/eno1/address (quiet=False)
2019-06-12 00:41:54,144 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/eno1/address
2019-06-12 00:41:54,144 - util.py[DEBUG]: Reading from /sys/class/net/eno1/device/device (quiet=False)
2019-06-12 00:41:54,145 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/eno1/device/device
2019-06-12 00:41:54,145 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/addr_assign_type (quiet=False)
2019-06-12 00:41:54,145 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/enp6s0f1/addr_assign_type
2019-06-12 00:41:54,145 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/uevent (quiet=False)
2019-06-12 00:41:54,145 - util.py[DEBUG]: Read 29 bytes from /sys/class/net/enp6s0f1/uevent
2019-06-12 00:41:54,145 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/address (quiet=False)
2019-06-12 00:41:54,145 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/enp6s0f1/address
2019-06-12 00:41:54,145 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/device/device (quiet=False)
2019-06-12 00:41:54,145 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/enp6s0f1/device/device
2019-06-12 00:41:54,145 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/addr_assign_type (quiet=False)
2019-06-12 00:41:54,145 - util.py[DEBUG]: Read 2 bytes from /sys/class/net/enp6s0f0/addr_assign_type
2019-06-12 00:41:54,145 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/uevent (quiet=False)
2019-06-12 00:41:54,145 - util.py[DEBUG]: Read 29 bytes from /sys/class/net/enp6s0f0/uevent
2019-06-12 00:41:54,145 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/address (quiet=False)
2019-06-12 00:41:54,145 - util.py[DEBUG]: Read 18 bytes from /sys/class/net/enp6s0f0/address
2019-06-12 00:41:54,145 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/device/device (quiet=False)
2019-06-12 00:41:54,146 - util.py[DEBUG]: Read 7 bytes from /sys/class/net/enp6s0f0/device/device
2019-06-12 00:41:54,146 - util.py[DEBUG]: Reading from /sys/class/net/lo/operstate (quiet=False)
2019-06-12 00:41:54,146 - util.py[DEBUG]: Read 8 bytes from /sys/class/net/lo/operstate
2019-06-12 00:41:54,146 - util.py[DEBUG]: Reading from /sys/class/net/eno2/operstate (quiet=False)
2019-06-12 00:41:54,146 - util.py[DEBUG]: Read 3 bytes from /sys/class/net/eno2/operstate
2019-06-12 00:41:54,146 - util.py[DEBUG]: Reading from /sys/class/net/eno1/operstate (quiet=False)
2019-06-12 00:41:54,146 - util.py[DEBUG]: Read 3 bytes from /sys/class/net/eno1/operstate
2019-06-12 00:41:54,146 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f1/operstate (quiet=False)
2019-06-12 00:41:54,146 - util.py[DEBUG]: Read 3 bytes from /sys/class/net/enp6s0f1/operstate
2019-06-12 00:41:54,146 - util.py[DEBUG]: Reading from /sys/class/net/enp6s0f0/operstate (quiet=False)
2019-06-12 00:41:54,146 - util.py[DEBUG]: Read 3 bytes from /sys/class/net/enp6s0f0/operstate
2019-06-12 00:41:54,146 - util.py[DEBUG]: Running command ['ip', '-6', 'addr', 'show', 'permanent', 'scope', 'global'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:54,148 - util.py[DEBUG]: Running command ['ip', '-4', 'addr', 'show'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:54,150 - __init__.py[DEBUG]: no work necessary for renaming of [['2c:60:0c:83:6c:f3', 'eno1', 'igb', '0x1521'], ['2c:60:0c:83:6c:f4', 'eno2', 'igb', '0x1521'], ['90:e2:ba:7e:c4:c0', 'enp6s0f0', 'ixgbe', '0x10fb'], ['90:e2:ba:7e:c4:c1', 'enp6s0f1', 'ixgbe', '0x10fb']]
2019-06-12 00:41:54,150 - stages.py[INFO]: Applying network configuration from system_cfg bringup=True: {'config': [{'name': 'eno1', 'mtu': 1500, 'subnets': [{'type': 'manual'}], 'type': 'physical', 'id': 'eno1', 'mac_address': '2c:60:0c:83:6c:f3'}, {'name': 'eno2', 'mtu': 1500, 'subnets': [{'gateway': '105.91.248.1', 'type': 'static', 'dns_nameservers': ['8.8.8.8'], 'address': '105.91.248.156/24', 'dns_search': ['maas']}], 'type': 'physical', 'id': 'eno2', 'mac_address': '2c:60:0c:83:6c:f4'}, {'name': 'enp6s0f0', 'mtu': 1500, 'subnets': [{'type': 'manual'}], 'type': 'physical', 'id': 'enp6s0f0', 'mac_address': '90:e2:ba:7e:c4:c0'}, {'name': 'enp6s0f1', 'mtu': 1500, 'subnets': [{'type': 'manual'}], 'type': 'physical', 'id': 'enp6s0f1', 'mac_address': '90:e2:ba:7e:c4:c1'}, {'search': ['maas'], 'type': 'nameserver', 'address': ['8.8.8.8']}], 'version': 1}
2019-06-12 00:41:54,150 - __init__.py[DEBUG]: Selected renderer 'eni' from priority list: None
2019-06-12 00:41:54,172 - util.py[DEBUG]: Writing to /etc/network/interfaces.d/50-cloud-init.cfg - wb: [644] 690 bytes
2019-06-12 00:41:54,172 - util.py[DEBUG]: Writing to /etc/udev/rules.d/70-persistent-net.rules - wb: [644] 392 bytes
2019-06-12 00:41:54,178 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,179 - handlers.py[DEBUG]: start: init-network/setup-datasource: setting up datasource
2019-06-12 00:41:54,185 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,185 - handlers.py[DEBUG]: finish: init-network/setup-datasource: SUCCESS: setting up datasource
2019-06-12 00:41:54,185 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/re6cck/user-data.txt - wb: [600] 912 bytes
2019-06-12 00:41:54,185 - util.py[DEBUG]: Attempting to load yaml from string of length 912 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,208 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/re6cck/user-data.txt.i - wb: [600] 1217 bytes
2019-06-12 00:41:54,208 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/re6cck/vendor-data.txt - wb: [600] 59 bytes
2019-06-12 00:41:54,209 - util.py[DEBUG]: Attempting to load yaml from string of length 59 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,210 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/re6cck/vendor-data.txt.i - wb: [600] 364 bytes
2019-06-12 00:41:54,211 - cc_set_hostname.py[DEBUG]: Setting the hostname to cacpu04.maas (cacpu04)
2019-06-12 00:41:54,211 - util.py[DEBUG]: Reading from /etc/hostname (quiet=False)
2019-06-12 00:41:54,211 - util.py[DEBUG]: Read 7 bytes from /etc/hostname
2019-06-12 00:41:54,211 - util.py[DEBUG]: Writing to /etc/hostname - wb: [644] 8 bytes
2019-06-12 00:41:54,212 - __init__.py[DEBUG]: Non-persistently setting the system hostname to cacpu04
2019-06-12 00:41:54,212 - util.py[DEBUG]: Running command ['hostname', 'cacpu04'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:54,214 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/re6cck/sem/consume_data - wb: [644] 25 bytes
2019-06-12 00:41:54,215 - helpers.py[DEBUG]: Running consume_data using lock (<FileLock using file '/var/lib/cloud/instances/re6cck/sem/consume_data'>)
2019-06-12 00:41:54,220 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,220 - handlers.py[DEBUG]: start: init-network/consume-user-data: reading and applying user-data
2019-06-12 00:41:54,221 - stages.py[DEBUG]: Added default handler for {'text/cloud-config', 'text/cloud-config-jsonp'} from CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']]
2019-06-12 00:41:54,221 - stages.py[DEBUG]: Added default handler for {'text/x-shellscript'} from ShellScriptPartHandler: [['text/x-shellscript']]
2019-06-12 00:41:54,221 - stages.py[DEBUG]: Added default handler for {'text/cloud-boothook'} from BootHookPartHandler: [['text/cloud-boothook']]
2019-06-12 00:41:54,221 - stages.py[DEBUG]: Added default handler for {'text/upstart-job'} from UpstartJobPartHandler: [['text/upstart-job']]
2019-06-12 00:41:54,221 - stages.py[DEBUG]: Added default handler for {'text/jinja2'} from JinjaTemplatePartHandler: [['text/jinja2']]
2019-06-12 00:41:54,221 - __init__.py[DEBUG]: Calling handler UpstartJobPartHandler: [['text/upstart-job']] (__begin__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,221 - __init__.py[DEBUG]: Calling handler JinjaTemplatePartHandler: [['text/jinja2']] (__begin__, None, 3) with frequency once-per-instance
2019-06-12 00:41:54,221 - __init__.py[DEBUG]: Calling handler BootHookPartHandler: [['text/cloud-boothook']] (__begin__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,221 - __init__.py[DEBUG]: Calling handler CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']] (__begin__, None, 3) with frequency once-per-instance
2019-06-12 00:41:54,221 - __init__.py[DEBUG]: Calling handler ShellScriptPartHandler: [['text/x-shellscript']] (__begin__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,221 - __init__.py[DEBUG]: {'Content-Disposition': 'attachment; filename="part-001"', 'Content-Type': 'text/cloud-config', 'MIME-Version': '1.0'}
2019-06-12 00:41:54,221 - __init__.py[DEBUG]: Calling handler CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']] (text/cloud-config, part-001, 3) with frequency once-per-instance
2019-06-12 00:41:54,222 - util.py[DEBUG]: Attempting to load yaml from string of length 912 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,224 - cloud_config.py[DEBUG]: Merging by applying [('dict', ['replace']), ('list', []), ('str', [])]
2019-06-12 00:41:54,224 - __init__.py[DEBUG]: Calling handler UpstartJobPartHandler: [['text/upstart-job']] (__end__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,224 - __init__.py[DEBUG]: Calling handler JinjaTemplatePartHandler: [['text/jinja2']] (__end__, None, 3) with frequency once-per-instance
2019-06-12 00:41:54,225 - __init__.py[DEBUG]: Calling handler BootHookPartHandler: [['text/cloud-boothook']] (__end__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,225 - __init__.py[DEBUG]: Calling handler CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']] (__end__, None, 3) with frequency once-per-instance
2019-06-12 00:41:54,226 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/re6cck/cloud-config.txt - wb: [600] 972 bytes
2019-06-12 00:41:54,227 - __init__.py[DEBUG]: Calling handler ShellScriptPartHandler: [['text/x-shellscript']] (__end__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,230 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,230 - handlers.py[DEBUG]: finish: init-network/consume-user-data: SUCCESS: reading and applying user-data
2019-06-12 00:41:54,233 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,233 - handlers.py[DEBUG]: start: init-network/consume-vendor-data: reading and applying vendor-data
2019-06-12 00:41:54,234 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/cloud-config.txt (quiet=False)
2019-06-12 00:41:54,234 - util.py[DEBUG]: Read 972 bytes from /var/lib/cloud/instance/cloud-config.txt
2019-06-12 00:41:54,234 - util.py[DEBUG]: Attempting to load yaml from string of length 972 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,236 - stages.py[DEBUG]: vendor data will be consumed. disabled_handlers=None
2019-06-12 00:41:54,237 - stages.py[DEBUG]: Added default handler for {'text/cloud-config', 'text/cloud-config-jsonp'} from CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']]
2019-06-12 00:41:54,237 - stages.py[DEBUG]: Added default handler for {'text/x-shellscript'} from ShellScriptPartHandler: [['text/x-shellscript']]
2019-06-12 00:41:54,237 - stages.py[DEBUG]: Added default handler for {'text/cloud-boothook'} from BootHookPartHandler: [['text/cloud-boothook']]
2019-06-12 00:41:54,237 - stages.py[DEBUG]: Added default handler for {'text/upstart-job'} from UpstartJobPartHandler: [['text/upstart-job']]
2019-06-12 00:41:54,237 - stages.py[DEBUG]: Added default handler for {'text/jinja2'} from JinjaTemplatePartHandler: [['text/jinja2']]
2019-06-12 00:41:54,237 - __init__.py[DEBUG]: Calling handler UpstartJobPartHandler: [['text/upstart-job']] (__begin__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,237 - __init__.py[DEBUG]: Calling handler JinjaTemplatePartHandler: [['text/jinja2']] (__begin__, None, 3) with frequency once-per-instance
2019-06-12 00:41:54,237 - __init__.py[DEBUG]: Calling handler BootHookPartHandler: [['text/cloud-boothook']] (__begin__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,238 - __init__.py[DEBUG]: Calling handler CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']] (__begin__, None, 3) with frequency once-per-instance
2019-06-12 00:41:54,238 - __init__.py[DEBUG]: Calling handler ShellScriptPartHandler: [['text/x-shellscript']] (__begin__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,238 - __init__.py[DEBUG]: {'Content-Disposition': 'attachment; filename="part-001"', 'Content-Type': 'text/cloud-config', 'MIME-Version': '1.0'}
2019-06-12 00:41:54,238 - __init__.py[DEBUG]: Calling handler CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']] (text/cloud-config, part-001, 3) with frequency once-per-instance
2019-06-12 00:41:54,238 - util.py[DEBUG]: Attempting to load yaml from string of length 59 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,238 - cloud_config.py[DEBUG]: Merging by applying [('dict', ['replace']), ('list', []), ('str', [])]
2019-06-12 00:41:54,239 - __init__.py[DEBUG]: Calling handler UpstartJobPartHandler: [['text/upstart-job']] (__end__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,239 - __init__.py[DEBUG]: Calling handler JinjaTemplatePartHandler: [['text/jinja2']] (__end__, None, 3) with frequency once-per-instance
2019-06-12 00:41:54,239 - __init__.py[DEBUG]: Calling handler BootHookPartHandler: [['text/cloud-boothook']] (__end__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,239 - __init__.py[DEBUG]: Calling handler CloudConfigPartHandler: [['text/cloud-config', 'text/cloud-config-jsonp']] (__end__, None, 3) with frequency once-per-instance
2019-06-12 00:41:54,239 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/re6cck/vendor-cloud-config.txt - wb: [600] 103 bytes
2019-06-12 00:41:54,240 - __init__.py[DEBUG]: Calling handler ShellScriptPartHandler: [['text/x-shellscript']] (__end__, None, 2) with frequency once-per-instance
2019-06-12 00:41:54,242 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,242 - handlers.py[DEBUG]: finish: init-network/consume-vendor-data: SUCCESS: reading and applying vendor-data
2019-06-12 00:41:54,243 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg (quiet=False)
2019-06-12 00:41:54,243 - util.py[DEBUG]: Read 3612 bytes from /etc/cloud/cloud.cfg
2019-06-12 00:41:54,243 - util.py[DEBUG]: Attempting to load yaml from string of length 3612 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,255 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/curtin-preserve-sources.cfg (quiet=False)
2019-06-12 00:41:54,255 - util.py[DEBUG]: Read 35 bytes from /etc/cloud/cloud.cfg.d/curtin-preserve-sources.cfg
2019-06-12 00:41:54,255 - util.py[DEBUG]: Attempting to load yaml from string of length 35 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,255 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg_maas.cfg (quiet=False)
2019-06-12 00:41:54,255 - util.py[DEBUG]: Read 316 bytes from /etc/cloud/cloud.cfg.d/90_dpkg_maas.cfg
2019-06-12 00:41:54,255 - util.py[DEBUG]: Attempting to load yaml from string of length 316 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,256 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg_local_cloud_config.cfg (quiet=False)
2019-06-12 00:41:54,256 - util.py[DEBUG]: Read 361 bytes from /etc/cloud/cloud.cfg.d/90_dpkg_local_cloud_config.cfg
2019-06-12 00:41:54,256 - util.py[DEBUG]: Attempting to load yaml from string of length 361 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,258 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/90_dpkg.cfg (quiet=False)
2019-06-12 00:41:54,258 - util.py[DEBUG]: Read 81 bytes from /etc/cloud/cloud.cfg.d/90_dpkg.cfg
2019-06-12 00:41:54,258 - util.py[DEBUG]: Attempting to load yaml from string of length 81 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,258 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/50-curtin-networking.cfg (quiet=False)
2019-06-12 00:41:54,258 - util.py[DEBUG]: Read 762 bytes from /etc/cloud/cloud.cfg.d/50-curtin-networking.cfg
2019-06-12 00:41:54,258 - util.py[DEBUG]: Attempting to load yaml from string of length 762 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,264 - util.py[DEBUG]: Reading from /etc/cloud/cloud.cfg.d/05_logging.cfg (quiet=False)
2019-06-12 00:41:54,264 - util.py[DEBUG]: Read 2057 bytes from /etc/cloud/cloud.cfg.d/05_logging.cfg
2019-06-12 00:41:54,264 - util.py[DEBUG]: Attempting to load yaml from string of length 2057 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,267 - util.py[DEBUG]: Reading from /run/cloud-init/cloud.cfg (quiet=False)
2019-06-12 00:41:54,267 - util.py[DEBUG]: Read 45 bytes from /run/cloud-init/cloud.cfg
2019-06-12 00:41:54,267 - util.py[DEBUG]: Attempting to load yaml from string of length 45 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,268 - util.py[DEBUG]: Attempting to load yaml from string of length 0 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,268 - util.py[DEBUG]: loaded blob returned None, returning default.
2019-06-12 00:41:54,268 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/cloud-config.txt (quiet=False)
2019-06-12 00:41:54,268 - util.py[DEBUG]: Read 972 bytes from /var/lib/cloud/instance/cloud-config.txt
2019-06-12 00:41:54,268 - util.py[DEBUG]: Attempting to load yaml from string of length 972 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,271 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/vendor-cloud-config.txt (quiet=False)
2019-06-12 00:41:54,271 - util.py[DEBUG]: Read 103 bytes from /var/lib/cloud/instance/vendor-cloud-config.txt
2019-06-12 00:41:54,271 - util.py[DEBUG]: Attempting to load yaml from string of length 103 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,273 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/cloud-config.txt (quiet=False)
2019-06-12 00:41:54,273 - util.py[DEBUG]: Read 972 bytes from /var/lib/cloud/instance/cloud-config.txt
2019-06-12 00:41:54,273 - util.py[DEBUG]: Attempting to load yaml from string of length 972 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,275 - util.py[DEBUG]: Reading from /var/lib/cloud/instance/vendor-cloud-config.txt (quiet=False)
2019-06-12 00:41:54,275 - util.py[DEBUG]: Read 103 bytes from /var/lib/cloud/instance/vendor-cloud-config.txt
2019-06-12 00:41:54,275 - util.py[DEBUG]: Attempting to load yaml from string of length 103 with allowed root types (<class 'dict'>,)
2019-06-12 00:41:54,281 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,281 - handlers.py[DEBUG]: start: init-network/activate-datasource: activating datasource
2019-06-12 00:41:54,281 - util.py[DEBUG]: Writing to /var/lib/cloud/instance/manual-clean - w: [644] 0 characters
2019-06-12 00:41:54,282 - util.py[DEBUG]: Writing to /var/lib/cloud/instance/obj.pkl - wb: [400] 12206 bytes
2019-06-12 00:41:54,289 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,289 - handlers.py[DEBUG]: finish: init-network/activate-datasource: SUCCESS: activating datasource
2019-06-12 00:41:54,289 - main.py[DEBUG]: used datasource 'DataSourceMAAS [http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/]' from 'MAAS' was in di_report's list: ['MAAS', 'None']
2019-06-12 00:41:54,303 - stages.py[DEBUG]: Using distro class <class 'cloudinit.distros.ubuntu.Distro'>
2019-06-12 00:41:54,303 - stages.py[DEBUG]: Running module migrator (<module 'cloudinit.config.cc_migrator' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_migrator.py'>) with frequency always
2019-06-12 00:41:54,309 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,309 - handlers.py[DEBUG]: start: init-network/config-migrator: running config-migrator with frequency always
2019-06-12 00:41:54,309 - helpers.py[DEBUG]: Running config-migrator using lock (<cloudinit.helpers.DummyLock object at 0x7fbf9d042048>)
2019-06-12 00:41:54,309 - cc_migrator.py[DEBUG]: Migrated 0 semaphore files to there canonicalized names
2019-06-12 00:41:54,315 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,315 - handlers.py[DEBUG]: finish: init-network/config-migrator: SUCCESS: config-migrator ran successfully
2019-06-12 00:41:54,315 - stages.py[DEBUG]: Running module seed_random (<module 'cloudinit.config.cc_seed_random' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_seed_random.py'>) with frequency once-per-instance
2019-06-12 00:41:54,322 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,322 - handlers.py[DEBUG]: start: init-network/config-seed_random: running config-seed_random with frequency once-per-instance
2019-06-12 00:41:54,322 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/re6cck/sem/config_seed_random - wb: [644] 25 bytes
2019-06-12 00:41:54,323 - helpers.py[DEBUG]: Running config-seed_random using lock (<FileLock using file '/var/lib/cloud/instances/re6cck/sem/config_seed_random'>)
2019-06-12 00:41:54,323 - cc_seed_random.py[DEBUG]: no command provided
2019-06-12 00:41:54,326 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,327 - handlers.py[DEBUG]: finish: init-network/config-seed_random: SUCCESS: config-seed_random ran successfully
2019-06-12 00:41:54,327 - stages.py[DEBUG]: Running module bootcmd (<module 'cloudinit.config.cc_bootcmd' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_bootcmd.py'>) with frequency always
2019-06-12 00:41:54,330 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,330 - handlers.py[DEBUG]: start: init-network/config-bootcmd: running config-bootcmd with frequency always
2019-06-12 00:41:54,330 - helpers.py[DEBUG]: Running config-bootcmd using lock (<cloudinit.helpers.DummyLock object at 0x7fbf9cfb6358>)
2019-06-12 00:41:54,330 - cc_bootcmd.py[DEBUG]: Skipping module named bootcmd, no 'bootcmd' key in configuration
2019-06-12 00:41:54,333 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,333 - handlers.py[DEBUG]: finish: init-network/config-bootcmd: SUCCESS: config-bootcmd ran successfully
2019-06-12 00:41:54,333 - stages.py[DEBUG]: Running module write-files (<module 'cloudinit.config.cc_write_files' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_write_files.py'>) with frequency once-per-instance
2019-06-12 00:41:54,336 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,336 - handlers.py[DEBUG]: start: init-network/config-write-files: running config-write-files with frequency once-per-instance
2019-06-12 00:41:54,336 - util.py[DEBUG]: Writing to /var/lib/cloud/instances/re6cck/sem/config_write_files - wb: [644] 25 bytes
2019-06-12 00:41:54,337 - helpers.py[DEBUG]: Running config-write-files using lock (<FileLock using file '/var/lib/cloud/instances/re6cck/sem/config_write_files'>)
2019-06-12 00:41:54,337 - util.py[DEBUG]: Writing to /var/tmp/workerconfig.yaml - wb: [644] 461 bytes
2019-06-12 00:41:54,337 - util.py[DEBUG]: Changing the ownership of /var/tmp/workerconfig.yaml to 0:0
2019-06-12 00:41:54,340 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,340 - handlers.py[DEBUG]: finish: init-network/config-write-files: SUCCESS: config-write-files ran successfully
2019-06-12 00:41:54,340 - stages.py[DEBUG]: Running module growpart (<module 'cloudinit.config.cc_growpart' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_growpart.py'>) with frequency always
2019-06-12 00:41:54,343 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,344 - handlers.py[DEBUG]: start: init-network/config-growpart: running config-growpart with frequency always
2019-06-12 00:41:54,344 - helpers.py[DEBUG]: Running config-growpart using lock (<cloudinit.helpers.DummyLock object at 0x7fbf9cfb6358>)
2019-06-12 00:41:54,344 - cc_growpart.py[DEBUG]: No 'growpart' entry in cfg. Using default: {'mode': 'auto', 'devices': ['/'], 'ignore_growroot_disabled': False}
2019-06-12 00:41:54,344 - util.py[DEBUG]: Running command ['growpart', '--help'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:54,353 - util.py[DEBUG]: Reading from /proc/1608/mountinfo (quiet=False)
2019-06-12 00:41:54,353 - util.py[DEBUG]: Read 2717 bytes from /proc/1608/mountinfo
2019-06-12 00:41:54,353 - util.py[DEBUG]: Running command ['systemd-detect-virt', '--quiet', '--container'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:54,355 - util.py[DEBUG]: Running command ['running-in-container'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:54,357 - util.py[DEBUG]: Running command ['lxc-is-container'] with allowed return codes [0] (shell=False, capture=True)
2019-06-12 00:41:54,358 - util.py[DEBUG]: Reading from /proc/1/environ (quiet=False)
2019-06-12 00:41:54,358 - util.py[DEBUG]: Read 176 bytes from /proc/1/environ
2019-06-12 00:41:54,358 - util.py[DEBUG]: Reading from /proc/self/status (quiet=False)
2019-06-12 00:41:54,359 - util.py[DEBUG]: Read 951 bytes from /proc/self/status
2019-06-12 00:41:54,362 - util.py[DEBUG]: Reading from /etc/os-release (quiet=False)
2019-06-12 00:41:54,362 - util.py[DEBUG]: Read 298 bytes from /etc/os-release
2019-06-12 00:41:54,363 - util.py[DEBUG]: resize_devices took 0.010 seconds
2019-06-12 00:41:54,363 - cc_growpart.py[DEBUG]: '/' SKIPPED: device_part_info(/dev/mapper/vgroot-lvroot) failed: /dev/mapper/vgroot-lvroot not a partition
2019-06-12 00:41:54,367 - url_helper.py[DEBUG]: Read from http://xxx.xxx.xxx.xxx:xxxx/MAAS/metadata/status/re6cck (204, 0b) after 1 attempts
2019-06-12 00:41:54,368 - handlers.py[DEBUG]: finish: init-network/config-growpart: SUCCESS: config-growpart ran successfully
2019-06-12 00:41:54,368 - stages.py[DEBUG]: Running module resizefs (<module 'cloudinit.config.cc_resizefs' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_resizefs.py'>) with frequency always
