I’m chasing some problems with adding new hosts to MaaS (as described in post 6507 on this forum) and one of the errors I ran into was, a node would PXE boot and begin enlisting but freeze after showing the error “cloud-init can not apply stage config no datasource found likely bad things to come.” Some googling gave me conflicting information about what the contents of /snap/maas/current/etc/maas/preseeds/enslist should be. Based on one post I found online (https://askubuntu.com/questions/1357662/maas-problems-with-enlisting-nodes) I should not be getting “Unrecognised signature: method=GET op=get_enlist_preseed” when I browse to [MAAS-ip]:5240/MAAS/metadata/enlist-preseed/?op=get_enlist_preseed, but that’s exactly the error I’m getting. So I checked my enlist file contents, and it simply has:
{{preseed_data}}
However, other posts are saying that the contents of this file should be something like:
#cloud-config
datasource:
MAAS:
timeout : 50
max_wait : 120
# there are no default values for metadata_url or oauth credentials
# If no credentials are present, non-authed attempts will be made.
metadata_url: http://<region_controller_ip>:5240/MAAS/metadata
What should the contents of this file be? Should I be getting something other than “Unrecognised signature: method=GET op=get_enlist_preseed” when I browse to the URL mentioned above?
