I just find ID 4 and ID 6 on the docs.
Where I can see the interpretation of these status id?
This table is missing from the documentation, thanks for pointing it out.
From the code:
# The node has been created and has a system ID assigned to it.
NEW = 0
# Testing and other commissioning steps are taking place.
COMMISSIONING = 1
# The commissioning step failed.
FAILED_COMMISSIONING = 2
# The node can't be contacted.
MISSING = 3
# The node is in the general pool ready to be deployed.
READY = 4
# The node is ready for named deployment.
RESERVED = 5
# The node has booted into the operating system of its owner's choice
# and is ready for use.
DEPLOYED = 6
# The node has been removed from service manually until an admin
# overrides the retirement.
RETIRED = 7
# The node is broken: a step in the node lifecyle failed.
# More details can be found in the node's event log.
BROKEN = 8
# The node is being installed.
DEPLOYING = 9
# The node has been allocated to a user and is ready for deployment.
ALLOCATED = 10
# The deployment of the node failed.
FAILED_DEPLOYMENT = 11
# The node is powering down after a release request.
RELEASING = 12
# The releasing of the node failed.
FAILED_RELEASING = 13
# The node is erasing its disks.
DISK_ERASING = 14
# The node failed to erase its disks.
FAILED_DISK_ERASING = 15
# The node is in rescue mode.
RESCUE_MODE = 16
# The node is entering rescue mode.
ENTERING_RESCUE_MODE = 17
# The node failed to enter rescue mode.
FAILED_ENTERING_RESCUE_MODE = 18
# The node is exiting rescue mode.
EXITING_RESCUE_MODE = 19
# The node failed to exit rescue mode.
FAILED_EXITING_RESCUE_MODE = 20
# Running tests on Node
TESTING = 21
# Testing has failed
FAILED_TESTING = 22
thx !! It worked for me
if you want a human readable status, then look at the status_name output from the CLI
e.g.
$ maas karura machines read | jq ".[] | \
{hostname:.hostname, system_id: .system_id, status_name:.status_name}" --compact-output
{"hostname":"grand-amoeba","system_id":"qt7e3e","status_name":"Ready"}
{"hostname":"grown-hawk","system_id":"8qcbef","status_name":"New"}
{"hostname":"living-goblin","system_id":"4qnwph","status_name":"Ready"}
{"hostname":"sure-quagga","system_id":"xpygmm","status_name":"Testing"}
{"hostname":"many-coyote","system_id":"h7rqdm","status_name":"Ready"}
{"hostname":"golden-liger","system_id":"etyhye","status_name":"Testing"}
{"hostname":"on-prawn","system_id":"8pes34","status_name":"Deployed"}
{"hostname":"immune-mullet","system_id":"b38mrp","status_name":"Ready"}
{"hostname":"sound-shiner","system_id":"etyht4","status_name":"Ready"}
