What are maas devices? http://server/MAAS/r/devices
Just curious what would go here and what they’re used for?
I found this documentation but not sure what the use case would be for.
https://canonical.com/maas/docs/device
Hi @steven-asg,
Everything discovered on a network accessible to MAAS is initially treated as a device. If you later provide BMC credentials for one of these devices and register it with MAAS, it becomes a machine. Some devices may not be manageable by MAAS (for example, those without supported BMCs), but they will still appear in the Devices section for visibility
This section in the documentation might help:
