see full issue here:
I noticed when this is happening, the node don’t have random hostname, but called somelike maas-enlistment
login, does anyone run into this?
what could be the reason that random hostname is missing?
seems that random hostname is unrelated to this issue, the enlistment hang because those server was deployed and there are some uncleaned records in database
some node report duplicate static ip address error when add machine manually
some node just hang there when add through web console, with no error, just timeout, regiond cpu running ta 100%
regiond.log:
2019-02-18 12:43:55 maasserver.utils.views: [error] Attempt #1 for /MAAS/api/2.0/machines/ failed; giving up (624.4s elapsed in total)
2019-02-18 12:43:55 -: [critical] WSGI application error
File “/usr/lib/python3/dist-packages/twisted/python/context.py”, line 122, in callWithContext
File “/usr/lib/python3/dist-packages/twisted/python/context.py”, line 87, in callWithContext
self.contexts.pop()
File “/usr/lib/python3/dist-packages/provisioningserver/utils/twisted.py”, line 885, in callInContext
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/twisted/web/wsgi.py”, line 522, in run
self.started = True
File “/usr/lib/python3/dist-packages/twisted/web/wsgi.py”, line 500, in run
self.write(elem)
File “/usr/lib/python3/dist-packages/twisted/web/wsgi.py”, line 455, in write
self.reactor, wsgiWrite, self.started)
File “/usr/lib/python3/dist-packages/twisted/internet/threads.py”, line 122, in blockingCallFromThread
result.raiseException()
File “/usr/lib/python3/dist-packages/twisted/python/failure.py”, line 385, in raiseException
raise self.value.with_traceback(self.tb)
builtins.AttributeError: ‘NoneType’ object has no attribute ‘writeHeaders’
2019-02-18 12:43:55 asyncio: [error] Exception in callback <function AsyncioSelectorReactor.callLater..run at 0x7f236ed82620>
handle: <Handle AsyncioSelectorReactor.callLater..run>
File “uvloop/cbhandles.pyx”, line 47, in uvloop.loop.Handle._run
File “/usr/lib/python3/dist-packages/twisted/internet/asyncioreactor.py”, line 290, in run
f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/twisted/web/wsgi.py”, line 510, in wsgiError
self.request.loseConnection()
File “/usr/lib/python3/dist-packages/twisted/web/http.py”, line 1474, in loseConnection
self.channel.loseConnection()
AttributeError: ‘NoneType’ object has no attribute ‘loseConnection’
