Create a logical volume
maas $PROFILE volume-group create-logical-volume [--help] [-d] [-k] system_id id
Positional arguments
- system_id
- id
Create a logical volume in the volume group with the given id on the machine with the given system_id.
Keyword “name”
Required String. Name of the logical volume.
Keyword “uuid”
Optional String. (optional) UUID of the logical volume.
Keyword “size”
Optional String. (optional) Size of the logical volume. Must be larger than or equal to 4,194,304 bytes. E.g. 4194304. Will default to free space in the volume group if not given.
Command-line options
| Option | Effect |
Delete volume group
maas $PROFILE volume-group delete [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Delete a volume group with the given id from the machine with the given system_id.
| Option | Effect |
Delete a logical volume
maas $PROFILE volume-group delete-logical-volume [--help] [-d] [-k] system_id id
- system_id
- id
Delete a logical volume in the volume group with the given id on the machine with the given system_id.
Note: this operation returns HTTP status code 204 even if the logical volume id does not exist.
Keyword “id”
Required Int. The logical volume id.
| Option | Effect |
Read a volume group
maas $PROFILE volume-group read [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Read a volume group with the given id on the machine with the given system_id.
| Option | Effect |
Update a volume group
maas $PROFILE volume-group update [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Update a volume group with the given id on the machine with the given system_id.
Keyword “name”
Optional String. Name of the volume group.
Keyword “uuid”
Optional String. UUID of the volume group.
Keyword “add_block_devices”
Optional String. Block devices to add to the volume group.
Keyword “remove_block_devices”
Optional String. Block devices to remove from the volume group.
Keyword “add_partitions”
Optional String. Partitions to add to the volume group.
Keyword “remove_partitions”
Optional String. Partitions to remove from the volume group.
| Option | Effect |
Create a volume group
maas $PROFILE volume-groups create [--help] [-d] [-k] system_id [data ...]
- system_id
Create a volume group belonging to a machine with the given system_id.
Note that at least one valid block device or partition is required.
Keyword “name”
Required String. Name of the volume group.
Keyword “uuid”
Optional String. (optional) UUID of the volume group.
Keyword “block_devices”
Keyword “partitions”
| Option | Effect |
List all volume groups
maas $PROFILE volume-groups read [--help] [-d] [-k] system_id [data ...]
- system_id
List all volume groups belonging to a machine with the given system_id.
| Option | Effect |
