Hello, I am interested is it possible to add virtual network interface card to a node controlled by MAAS?
I take it you mean, for a KVM machine? We intend to model openvswitch (OVS) in netplan, curtin and then MAAS. That would be a useful general scaffold to provide what you’re looking for.
I mean bare metal node. Not a KVM machine. https://jaas.ai/openstack-base. It says that I need 2 NIC. I would prefer to use only one physical for each node and the second would be virtual network interface card added via maas. Is it possible?
I read about VLANs https://maas.io/docs/cli-interface-management. But I am not sure if it will work in this installation https://jaas.ai/openstack-base
Ah, OK, now I understand what you mean.
Our current reference architecture for OpenStack uses two different NICs, but we are currently working to update that architecture to use a single NIC (or single bond). As part of that work, we want to make use of OVS and virtual nic’s as you suggest, but that is not currently available. I am not sure how best to advise you - I believe it is possible to build OpenStack with a single nic per server of course, but you’ll need to wade through some details that I don’t have handy.
So, as I understand it is impossible to use only one NIC of any kind juju and maas for openstack deployment?
I believe it is possible to do what you want. I just don’t have any pointers to a step-by-step instruction guide. We are planning to update our step-by-step instructions to a single NIC but I think that we wanted to do that based on new features coming in the next versions of MAAS and Juju.
