Hi
I am lucky to have a i7 win10 laptop with 64G RAM, I like to create all-in-one VM to run mini openstack farm on ubuntu 20.4.5, using juju for learning purpose.
I looked at R1 similar issue I have now and was able install the dependency
I am still not sure this is a juju or maas or vmware issue(tried both on ESXi and Windows VMWare Fusion).
I also tried the latest juju/lxd/maas channel but only have more verbose message when running
following command.
juju bootstrap --config default-series="focal" --config bootstrap-timeout=1200 maas maas-controller
- OS info
me@u20t01:~$ cat /etc/os-release ;df -lh |grep loop
NAME="Ubuntu"
VERSION="20.04.5 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.5 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
/dev/loop2 64M 64M 0 100% /snap/core20/1822
/dev/loop1 62M 62M 0 100% /snap/core20/1611
/dev/loop0 56M 56M 0 100% /snap/core18/2679
/dev/loop5 93M 93M 0 100% /snap/juju/21790
/dev/loop3 38M 38M 0 100% /snap/maas-test-db/53
/dev/loop4 143M 143M 0 100% /snap/maas/12555
/dev/loop6 92M 92M 0 100% /snap/lxd/24061
/dev/loop7 15M 15M 0 100% /snap/maas-cli/79
/dev/loop8 50M 50M 0 100% /snap/snapd/17950
me@u20t01:~$
- kvm-ok
me@u20t01:~$ kvm-ok
INFO: /dev/kvm exists
KVM acceleration can be used
me@u20t01:~$
me@u20t01:~$ sudo lsmod | sort | egrep 'kvm|vhost|vsock'
kvm 663552 1 kvm_intel
kvm_intel 282624 0
vhost 49152 0
vmw_vmci 69632 2 vmw_balloon,vmw_vsock_vmci_transport
vmw_vsock_virtio_transport_common 36864 0
vmw_vsock_vmci_transport 32768 1
vsock 40960 3 vmw_vsock_virtio_transport_common,vmw_vsock_vmci_transport
me@u20t01:~$
- maas status
me@u20t01:~$ sudo maas status
bind9 RUNNING pid 16313, uptime 0:38:24
dhcpd RUNNING pid 19513, uptime 0:31:26
dhcpd6 STOPPED Not started
http RUNNING pid 16677, uptime 0:37:59
ntp RUNNING pid 16481, uptime 0:38:06
proxy RUNNING pid 18894, uptime 0:35:43
rackd RUNNING pid 16317, uptime 0:38:24
regiond RUNNING pid 16320, uptime 0:38:24
syslog RUNNING pid 16478, uptime 0:38:06
me@u20t01:~$
- dmesg has DENIED message
me@u20t01:~$ dmesg |grep DENIED | tail -2
[ 2386.350657] audit: type=1400 audit(1676325338.425:1804): apparmor="DENIED" operation="open" profile="snap.maas.supervisor" name="/etc/squid/errorpage.css" pid=16768 comm="squid" requested_mask="r" denied_mask="r" fsuid=584788 ouid=0
[ 2517.704090] audit: type=1400 audit(1676325469.776:1816): apparmor="DENIED" operation="open" profile="snap.maas.supervisor" name="/etc/squid/errorpage.css" pid=18897 comm="squid" requested_mask="r" denied_mask="r" fsuid=584788 ouid=0
me@u20t01:~$
- No available machine matches constraint showing up also when in interactive mode.
me@u20t01:~/$ juju bootstrap --config default-series="focal" --config bootstrap-timeout=1200
Clouds
aws
aws-china
aws-gov
azure
azure-china
equinix
google
localhost
maas
oracle
Select a cloud [localhost]: maas
Enter a name for the Controller [maas-default]:
Creating Juju controller "maas-default" on maas/default
Looking for packaged Juju agent version 2.9.38 for amd64
Located Juju agent version 2.9.38-ubuntu-amd64 at https://streams.canonical.com/juju/tools/agent/2.9.38/juju-2.9.38-linux-amd64.tgz
Launching controller instance(s) on maas/default...
ERROR failed to bootstrap model: cannot start bootstrap instance in availability zone "default": failed to acquire node: No available machine matches constraints: [('agent_name', ['6a75\
c02c-37ac-48d0-841d-457222a34dca']), ('mem', ['3584']), ('zone', ['default'])] (resolved to "mem=3584.0 zone=default")
me@u20t01:~/$
- I still don’t know what exactly is local/local controller option but it was created fine.
Clouds
aws
aws-china
aws-gov
azure
azure-china
equinix
google
localhost
maas
oracle
Select a cloud [localhost]: localhost
Enter a name for the Controller [localhost-localhost]:
Creating Juju controller "localhost-localhost" on localhost/localhost
To configure your system to better support LXD containers, please see: https://linuxcontainers.org/lxd/docs/master/explanation/performance_tuning/
Launching controller instance(s) on localhost/localhost...
- juju-1c87d3-0 (arch=amd64)
Installing Juju agent on bootstrap instance
Fetching Juju Dashboard 0.8.1
Waiting for address
Attempting to connect to 10.0.8.150:22
Connected to 10.0.8.150
Running machine configuration script...
Bootstrap agent now started
Contacting Juju controller at 10.0.8.150 to verify accessibility...
Bootstrap complete, controller "localhost-localhost" is now available
Controller machines are in the "controller" model
Initial model "default" added
me@u20t01:~/$
