Delete the specified VMFS datastore.
maas $PROFILE vmfs-datastore delete [--help] [-d] [-k] system_id id [data ...]
Positional arguments
- system_id
- id
Delete a VMFS datastore with the given id from the machine with the given system_id.
Command-line options
| Option | Effect |
| –help, -h | Show this help message and exit |
| -d, --debug | Display more information about API responses |
Read a VMFS datastore.
maas $PROFILE vmfs-datastore read [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Read a VMFS datastore with the given id on the machine with the given system_id.
| Option | Effect |
Update a VMFS datastore.
maas $PROFILE vmfs-datastore update [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Update a VMFS datastore with the given id on the machine with the given system_id.
Keyword “name”
Optional String. Name of the VMFS datastore.
Keyword “uuid”
Optional String. UUID of the VMFS datastore.
Keyword “add_block_devices”
Optional String. Block devices to add to the VMFS datastore.
Keyword “add_partitions”
Optional String. Partitions to add to the VMFS datastore.
Keyword “remove_partitions”
Optional String. Partitions to remove from the VMFS datastore.
| Option | Effect |
Create a VMFS datastore.
maas $PROFILE vmfs-datastores create [--help] [-d] [-k] system_id [data ...]
- system_id
Create a VMFS datastore belonging to a machine with the given system_id.
Note that at least one valid block device or partition is required.
Keyword “name”
Required String. Name of the VMFS datastore.
Keyword “uuid”
Optional String. (optional) UUID of the VMFS group.
Keyword “block_devices”
Keyword “partitions”
| Option | Effect |
List all VMFS datastores.
maas $PROFILE vmfs-datastores read [--help] [-d] [-k] system_id [data ...]
- system_id
List all VMFS datastores belonging to a machine with the given system_id.
| Option | Effect |
