Deletes a VM cluster
maas $PROFILE vm-cluster delete [--help] [-d] [-k] id [data ...]
Positional arguments
- id
Deletes a VM cluster with the given ID.
Keyword “decompose”
Optional Boolean. Whether to also decompose all machines in the VM cluster on removal. If not provided, machines will not be removed.
Command-line options
| Option | Effect |
| –help, -h | Show this help message and exit |
| -d, --debug | Display more information about API responses |
This operation has been deprecated in favor of ‘Virtual-machine-host read’.
maas $PROFILE vm-cluster read [--help] [-d] [-k] id [data ...]
- id
| Option | Effect |
Update a VM cluster
maas $PROFILE vm-cluster update [--help] [-d] [-k] id [data ...]
- id
Update a specific VM cluster by ID.
Keyword “name”
Optional String. The VM cluster’s name.
Keyword “pool”
Optional String. The name of the resource pool associated with this VM Cluster – this change is propagated to VM hosts
Keyword “zone”
Optional String. The VM cluster’s zone.
| Option | Effect |
