Delete a VLAN
maas $PROFILE vlan delete [--help] [-d] [-k] fabric_id vid [data ...]
Positional arguments
- fabric_id
- vid
Delete VLAN on a given fabric.
Command-line options
| Option | Effect |
| –help, -h | Show this help message and exit |
| -d, --debug | Display more information about API responses |
Retrieve VLAN
maas $PROFILE vlan read [--help] [-d] [-k] fabric_id vid [data ...]
- fabric_id
- vid
Retrieves a VLAN on a given fabric_id.
| Option | Effect |
Update VLAN
maas $PROFILE vlan update [--help] [-d] [-k] fabric_id vid [data ...]
- fabric_id
- vid
Updates a given VLAN.
Keyword “name”
Optional String. Name of the VLAN.
Keyword “description”
Optional String. Description of the VLAN.
Keyword “mtu”
Optional Int. The MTU to use on the VLAN.
Keyword “dhcp_on”
Optional Boolean. Whether or not DHCP should be managed on the VLAN.
Keyword “primary_rack”
Optional String. The primary rack controller managing the VLAN (system_id).
Keyword “secondary_rack”
Optional String. The secondary rack controller managing the VLAN (system_id).
Keyword “relay_vlan”
Optional Int. Relay VLAN ID. Only set when this VLAN will be using a DHCP relay to forward DHCP requests to another VLAN that MAAS is managing. MAAS will not run the DHCP relay itself, it must be configured to proxy requests to the primary and/or secondary rack controller interfaces for the VLAN specified in this field.
Keyword “space”
Optional String. The space this VLAN should be placed in. Passing in an empty string (or the string ‘undefined’) will cause the VLAN to be placed in the ‘undefined’ space.
| Option | Effect |
Create a VLAN
maas $PROFILE vlans create [--help] [-d] [-k] fabric_id [data ...]
- fabric_id
Creates a new VLAN.
Keyword “name”
Optional String. Description of the new VLAN.
Keyword “vid”
Required Int. VLAN ID of the new VLAN.
Keyword “mtu”
Keyword “space”
| Option | Effect |
List VLANs
maas $PROFILE vlans read [--help] [-d] [-k] fabric_id [data ...]
- fabric_id
List all VLANs belonging to given fabric.
| Option | Effect |
