Hi everyone,
I am trying to deploy some nodes in a VLAN “infected” environment and I must be doing something wrong as the interface created in 18.04 are not vlan ready.
In my MAAS interface, I can see the vlan, but in the netplan configuration generated, I don’t see any vlan part.
Are you guys able to deploy interfaces with vlans?
Thanks in advance and kudos for the team for a great pece on software
I am using MAAS version 2.6.1
I am posting some extract of the “interface_set” part maas nodes read output below and further down the netplan configuration in a deployed node in 18.04.
"links": [
"id": 153,
"mode": "static",
"ip_address": "10.234.174.6",
"subnet": {
"name": "10.234.172.0/22",
"vlan": {
"vid": 15,
"mtu": 1500,
"dhcp_on": false,
"external_dhcp": "10.234.172.51",
"relay_vlan": null,
"primary_rack": null,
"name": "15",
"space": "undefined",
"fabric_id": 2,
"fabric": "hebex",
"id": 5004,
"secondary_rack": null,
"cidr": "10.234.172.0/22",
"rdns_mode": 2,
"gateway_ip": "10.234.172.4",
"dns_servers": [],
"allow_dns": true,
"allow_proxy": true,
"active_discovery": false,
"managed": true,
"id": 3,
"resource_uri": "/MAAS/api/2.0/subnets/3/"
And the netplan generated without vlan part:
network:
ethernets:
enp3s0f0:
dhcp4: true
match:
macaddress: e4:11:5b:11:55:84
mtu: 1500
set-name: enp3s0f0
enp4s0f0:
match:
macaddress: e4:11:5b:11:55:88
mtu: 1500
set-name: enp4s0f0
enp4s0f1:
match:
macaddress: e4:11:5b:11:55:8a
mtu: 1500
set-name: enp4s0f1
vlan15:
addresses:
- 10.234.174.6/22
gateway4: 10.234.172.4
match:
macaddress: e4:11:5b:11:55:86
mtu: 1500
nameservers:
addresses:
- 192.168.200.1
- 10.98.250.115
search:
- maas
set-name: vlan15
version: 2
