Does MAAS support (or plan to support) Unified Kernel Images for installation and booting from?
I’m looking at using mkosi to build images, as I’m finding it a little easier to use than Packer, and it’s very easy to customise your build. It primarily builds with UKIs (but may be able to do the traditional stuff as well, which I will look at if there’s no UKI support in MAAS).
Thanks,
Will.
