How to use machine tags
Assign machine tags (3.4/UI)
If you want to create a new tag, and simultaneously assign it to one or more machines, select Machines > machine(s) (checkbox) > Categorise > Tag. Create and/or assign the tag, and then Save your work.
Assign machine tags (3.3–/UI)
If you want to create a new tag, and simultaneously assign it to one or more machines, select Machines > machine(s) (checkbox) > Take action > Tag. Create and/or assign the desired tag, and select Tag machine to register your changes.
Assign machine tags (CLI)
For example:
maas admin tag update-nodes new_tag add=g6arks
   "added": 1,
   "removed": 0
| @tsv' | column -t
hostname       sysid   machine_tags
divine-stork   8b3ypp  pod-console-logging  virtual
casual-prawn   4end6r  pod-console-logging  virtual
driven-teal    tgaat6  pod-console-logging  virtual
immune-beetle  43xand  pod-console-logging  virtual
good-osprey    napfxk  pod-console-logging  virtual
smart-hen      c4rwq7  pod-console-logging  virtual
boss-satyr     xn8taa  pod-console-logging  androko
golden-martin  8fxery  pod-console-logging  virtual
crack-guinea   qk4b3g  pod-console-logging  virtual
finer-leech    cy3dtr  pod-console-logging  virtual
free-mouse     gxtbq4  pod-console-logging  virtual
humble-bunny   srqnnb  pod-console-logging  virtual
wanted-muskox  ekw7fh  pod-console-logging  virtual
one-boa        by477d  pod-console-logging  virtual
great-urchin   srnx4g  pod-console-logging  virtual
ace-frog       g6arwg  pod-console-logging  virtual  barbar  farquar  new_tag
alive-marlin   gbwnfb  pod-console-logging  virtual
picked-parrot  am77wn  pod-console-logging  virtual
tough-kit      ke3wc7  pod-console-logging  virtual
legal-whale    8nq3mt  pod-console-logging  virtual
game-sponge    76pdc6  pod-console-logging  virtual
fun-ghoul      qxfm7k  pod-console-logging  virtual
aware-earwig   8m8hs7  pod-console-logging  virtual
chief-crane    7fapx7  pod-console-logging  virtual
select-tapir   4ascbr  pod-console-logging  virtual
on-slug        snfs8d  pod-console-logging  virtual
polite-llama   dbqd4m  pod-console-logging  virtual
frank-coyote   wcmk48  pod-console-logging  virtual
usable-condor  ed8hmy  pod-console-logging  virtual
still-imp      h6ra6d  pod-console-logging  virtual
Remove machine tags (3.4/UI)
To remove machine tags from a machine, select Machines > machine > Machine summary > Tags > Edit and remove the tag.
Remove machine tags (3.3–/UI)
To remove machine tags from a machine, select Machines > machine > Machine summary > Tags > Configuration > Edit and remove the tag.
Remove machine tags (CLI)
For example:
    "added": 0,
    "removed": 1
Change tags for multiple machines
This functionality can only be accessed via the MAAS CLI.
    "added": 2,
    "removed": 1
| @tsv' | column -t
golden-martin  8fxery  pod-console-logging  virtual  barbar
one-boa        by477d  pod-console-logging  virtual  barbar
ace-frog       g6arwg  pod-console-logging  virtual  farquar
List machine tags (3.4/UI)
In the MAAS UI, you don’t explicitly list all machine tags; instead, you filter by them using the “Filters” drop-down. Select Machines > Filters > Tags and click on one or more tag names. The machine list will automatically filter by (be limited to) the machines matching the selected tag(s). Remove a tag from the search filter by deselecting it in the Tags section.
List machine tags (3.3–/UI)
  • To list all tags, visit the ‘Machines’ tab and expand the ‘Tags’ subsection in the left pane. In this view, you can use tags as machine search filters.
  • Select one or several tags. The machines that satisfy all selected tags will display on the right pane. Notice there is a search field at the top of the right pane. You can type a search expression into this field.
List machine tags (CLI)
For example:
| @tsv' | column -t
View machine tags (3.4/UI)
To view the tags assigned to a specific machine, select Machines > machine > Configuration > Tags.
View machine tags (3.3–/UI)
  • On the machine list, select the machine of interest by clicking on its name.
  • On the machine detail screen that comes up, look for the tags on one of the cards presented there: the tags for that machine should be listed there.
View machine tags (CLI)
For example:
| @tsv' | column -t
Discover your virtual machine host ID
This functionality is available only through the MAAS CLI.
maas $PROFILE vmhosts read \
| @tsv' | column -t
For example:
maas admin vmhosts read \
| @tsv' | column -t
vm_host_name      id
my-lxd-vm-host-1  1
Assign tags to a VM host
maas $PROFILE vmhost add-tag $VMHOST_ID	tag=$TAG_NAME
If it worked, this should return Success, followed by the JSON that describes the VM host.
Remove VM host tags
List VM host tags
For example:
vm_host_name      id  tags
my-lxd-vm-host-1  1   morkopongo  pod-console-logging  virtual
View VM host tags (3.4/UI)
To view the machine tags assigned to a VM host, select KVM > VM host type > VM host > KVM host settings > Tags. You can also edit, add, or delete tags from this view. Note that you can only see the tags for a VM host in the same place that you change it. For a more comprehensive list of VM host tags, use the MAAS CLI.
View VM host tags (3.3–/UI)
To view the machine tags assigned to a VM host, select KVM > VM host > KVM host settings > *Tags. You can also edit, add, or delete tags from this view. Note that you can only see the tags for a VM host in the same place that you change it. For a more comprehensive list of VM host tags, use the MAAS CLI.
View VM host tags (CLI)
| @tsv' | column -t
name              id  tags
