Many MAAS users maintain their data centres in an air-gapped environment – that is, one that does not have an external Internet connection. MAAS runs well in this configuration, though keeping MAAS supplied with updates and images requires a bit of extra effort.
- Snap updates (via the snap proxy)
- Packages (via a local repo, possibly with a transparent proxy)
- MAAS-maintained images (via local mirror, possibly with a transparent proxy)
- Other OS images (various methods)
Five questions you may have:
- How do I use the snap proxy to refresh snaps in an air-gapped environment?
- How do I make package updates available in an air-gapped environment?
- How do I retrieve or update MAAS images in an air-gapped environment?
- How do I retrieve or update non-MAAS-maintained images in an air-gapped environment?
- How do I set up a transparent proxy?
Using the snap proxy
- Register an offline Snap Store Proxy on an Internet-connected machine.
- Set up HTTPS access to ensure adequate security.
- Fetch the necessary snaps as needed by your MAAS environment (on the Internet-connected machine).
Using local package repos
The simplest way to use local package repos is via the reprepro command. There is an older command, apt-mirror
, which is no longer maintained; it’s not recommended.
The reprepro
command manages a local repository of Debian packages. You can add files manually or download them from some other repository. It does not require an external database. This command also handles signatures of mirrored repos, and can create signatures for the generated package indices, if desired.
Local image mirrors
- Install the
simplestreams
package. - Define some variables to simplify CLI usage.
- Create the desired mirrors, specifying where you want your images stored.
- Set up a new boot source on your local server, referring to the local mirror.
- Use
user_data
. - Create custom images and store them in your local mirror.
A user can create custom user_data
which will configure CentOS or RHEL to use a specific mirror. Check out the custom machine setup page for details on how to make this work.
Creating a transparent proxy
- Configure Ubuntu to get packages via HTTP.
- Configure MAAS to get packages via HTTP.
- Create a local mirror repo for
archive.ubuntu.com
. - Create a local image mirror for
images.maas.io
. - Configure DNS to point to the local mirrors for both of those URLs.
