Hi all,
I’m running a MAAS setup to manage my cluster, with LXD as the VM host. The initial configuration works fine, but I’ve run into a storage limitation:
- The default disk I set up for MAAS/LXD is now full.
- I’ve added another HDD to the server and made it available to LXD.
- However, I’m struggling to move existing VMs to the new disk, or to configure MAAS so that new VMs are created on this additional disk.
What’s the recommended way to:
- Add an additional disk to LXD and make it usable by MAAS?
- Either move existing VMs to the new disk or configure new VM creation to use it?
Thanks in advance!
