Hi, I could not find instructions on upgrading from MAAS 2.6 to 2.8. How do I do it?
It’s been a while, but I’ll caution to say the snap with —classic.
so, @db0west, the 2.6 snap should only have installed as a snap with --devmode.
can you do a ‘sudo snap list’ and see if you have the 2.6 snap?
I used apt. It showed up with sudo apt list | grep maas
dw@maas-effect:~/src/homelab/maas_control$ sudo apt list | grep maas
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
maas/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed]
maas-cli/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed,automatic]
maas-common/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed,automatic]
maas-dhcp/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed,automatic]
maas-dns/bionic,bionic 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all
maas-enlist/bionic 0.4+bzr38-0ubuntu3 amd64
maas-proxy/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed,automatic]
maas-rack-controller/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed,automatic]
maas-region-api/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed,automatic]
maas-region-controller/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed,automatic]
python3-django-maas/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed,automatic]
python3-libmaas/bionic,bionic 0.6.4-0ubuntu1~18.04.1 all
python3-maas-client/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed,automatic]
python3-maas-provisioningserver/bionic,bionic,now 2.6.2-7841-ga10625be3-0ubuntu1~18.04.1 all [installed,automatic]
I just discovered some instructions with
sudo add-apt-repository ppa:maas/2.6
in them.
I surmised that there was a ppa:maas/2.8
It indeed looks like it is a thing. I am in the middle of a juju
deployment so I will wait for the actual upgrade, but adding the ppa
seems to have worked and the output from add-apt-repository
looked promising.
dw@maas-effect:~$ sudo add-apt-repository ppa:maas/2.8
[sudo] password for dw:
For stable releases of 2.8.x
Hit:1 http://prerelease.keybase.io/deb stable InRelease
Get:22 http://ppa.launchpad.net/maas/2.8/ubuntu bionic/main Translation-en [2,904 B]
Fetched 4,783 kB in 2s (2,426 kB/s)
Reading package lists... Done
That was indeed a valid upgrade path. Will apt
continue to be a supported upgrade path? Should I backup my server, decommission the apt
installed instance, and restore to a snap
@db0west, apt is still supported as of now, and we are expecting to have a ppa:maas/2.9 – but we are encouraging users to move to the snap. You should always back up your server after updates like this, of course, but if you can decommission the apt and restore to a snap, that’s probably a step into the future. I wouldn’t take it too lightly: do you have a test rig to try the apt --> snap switch before live updating?
