Hi guys,
I upgraded Maas to 3.3.4 and Postgresql from 10 to 12, but since it’s deprecated now I would like to upgrade it to 14.
I followed this procedure and it worked like a charm to upgrade to 12:
I tried to use the same to go to 14 and I have less success, I can run all the commands and upgrade the DB:
$ sudo -u postgres psql -c "SELECT version();"
version
PostgreSQL 14.8 (Ubuntu 14.8-0ubuntu0.22.04.1) on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 11.3.0-1ubuntu1~22.04.1) 11.3.0, 64-bit
(1 row)
But Maas does not like it, when I load the dashboard I got this:
The server connection failed with the error "Bad Gateway".
It looks like a login issue from regiond service and I can also see errors about RPC on rackd:
$ sudo systemctl status maas-regiond maas-rackd
● maas-regiond.service - MAAS Region Controller
Loaded: loaded (/lib/systemd/system/maas-regiond.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2023-06-26 06:36:06 UTC; 1min 24s ago
Docs: https://maas.io/
Main PID: 996 (sh)
Tasks: 3 (limit: 19010)
Memory: 113.1M
CPU: 4.396s
CGroup: /system.slice/maas-regiond.service
├─ 996 /bin/sh -c "exec /usr/sbin/regiond 2>&1 | tee -a \$LOGFILE"
├─1082 /usr/bin/python3 /usr/sbin/regiond
└─1083 tee -a /var/log/maas/regiond.log
Jun 26 06:37:30 dc1-it-maas-01 sh[1083]: File "/usr/lib/python3/dist-packages/django/db/backends/base/base.py", line 200, in connect
Jun 26 06:37:30 dc1-it-maas-01 sh[1083]: self.connection = self.get_new_connection(conn_params)
Jun 26 06:37:30 dc1-it-maas-01 sh[1083]: File "/usr/lib/python3/dist-packages/django/utils/asyncio.py", line 33, in inner
Jun 26 06:37:30 dc1-it-maas-01 sh[1083]: return func(*args, **kwargs)
Jun 26 06:37:30 dc1-it-maas-01 sh[1083]: File "/usr/lib/python3/dist-packages/django/db/backends/postgresql/base.py", line 187, in get_new_connection
Jun 26 06:37:30 dc1-it-maas-01 sh[1083]: connection = Database.connect(**conn_params)
Jun 26 06:37:30 dc1-it-maas-01 sh[1083]: File "/usr/lib/python3/dist-packages/psycopg2/__init__.py", line 122, in connect
Jun 26 06:37:30 dc1-it-maas-01 sh[1083]: conn = _connect(dsn, connection_factory=connection_factory, **kwasync)
Jun 26 06:37:30 dc1-it-maas-01 sh[1083]: django.db.utils.OperationalError: connection to server at "localhost" (::1), port 5432 failed: FATAL: password authentication failed for user "maas"
Jun 26 06:37:30 dc1-it-maas-01 sh[1083]: connection to server at "localhost" (::1), port 5432 failed: FATAL: password authentication failed for user "maas"
● maas-rackd.service - MAAS Rack Controller
Loaded: loaded (/lib/systemd/system/maas-rackd.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2023-06-26 06:36:07 UTC; 1min 24s ago
Process: 995 ExecStartPre=/bin/rm -f /var/lib/maas/dhcpd.sock (code=exited, status=0/SUCCESS)
Process: 1079 ExecStartPre=/bin/rm -f /var/lib/maas/dhcpd.conf (code=exited, status=0/SUCCESS)
Process: 1136 ExecStartPre=/bin/rm -f /var/lib/maas/dhcpd6.conf (code=exited, status=0/SUCCESS)
Main PID: 1139 (sh)
Tasks: 9 (limit: 19010)
Memory: 193.0M
CPU: 4.697s
CGroup: /system.slice/maas-rackd.service
├─1139 /bin/sh -c "exec /usr/sbin/rackd 2>&1 | tee -a \$LOGFILE"
├─1143 /usr/bin/python3 /usr/sbin/rackd
├─1144 tee -a /var/log/maas/rackd.log
├─1651 /usr/bin/python3 /usr/lib/maas/maas-common observe-beacons ens160
├─1691 sudo -n /usr/lib/maas/beacon-monitor ens160
└─1692 /usr/bin/tcpdump -Z root --interface ens160 --direction=in --no-promiscuous-mode --packet-buffered --immediate-mode --snapshot-length=16384 -n -w - "(udp dst port 5240) or (vlan and udp dst port 5240)"
Jun 26 06:37:27 dc1-it-maas-01 sh[1144]: 2023-06-26 06:37:27 provisioningserver.rpc.clusterservice: [info] Region is not advertising RPC endpoints. (While requesting RPC info at http://localhost:5240/MAAS)
However the password did not change in regiond.conf
Am I missing something?
Thank you!
