Upgrade Failed to 3.5.0 from 3.3.7?
Hello there,
I upgraded MAAS 3.5.0 (on Ubuntu 22.04.4).
$ dpkg -l maas
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name           Version                                    Architecture Description
ii  maas           1:3.3.7-13246-g.2341ebf5d-0ubuntu1~22.04.1 all          "Metal as a Service" is a physical cloud and IPAM
$ sudo apt-add-repository ppa:maas/3.5
$ sudo apt-get -y update
$ sudo apt-get -y dist-upgrade maas
$ sudo reboot
Then the following screen seems to be displayed, but nothing else is displayed.
Also, you will not be able to resolve the name by MAAS DNS.
Is there a workaround?
P.S.
I was able to restore it to normal operation with the original MAAS 3.3.7 by restoring from the snapshot of Linux KVM.
Could you please look at the logs to check what happened?
journalctl -t maas-regiond
Also, how long did you wait before giving up?
Thanks r00ta.
Journalctl outputs No entries.
$ journalctl -t maas-regiond
-- No entries --
$ journalctl -t maas-rackd
-- No entries --
Region is not advertising RPC endpoints. It is displayed.
$ sudo systemctl status maas-rackd.service
● maas-rackd.service - MAAS Rack Controller
     Loaded: loaded (/lib/systemd/system/maas-rackd.service; enabled; vendor preset: enabled)
     Active: active (running) since Tue 2024-07-16 07:25:52 UTC; 45s ago
       Docs: https://maas.io/docs
    Process: 9196 ExecStartPre=/bin/rm -f /var/lib/maas/dhcpd.sock /var/lib/maas/dhcpd.conf /var/lib/maas/dhcpd6.conf (code=e>
   Main PID: 9197 (rackd)
      Tasks: 7 (limit: 9388)
     Memory: 105.8M
        CPU: 4.975s
     CGroup: /system.slice/maas-rackd.service
             β”œβ”€9197 /usr/bin/python3 /usr/sbin/rackd
             β”œβ”€9278 /usr/bin/python3 /usr/lib/maas/maas-common observe-beacons ens3
             β”œβ”€9304 sudo -n /usr/lib/maas/beacon-monitor ens3
             └─9305 /usr/bin/tcpdump -Z root --interface ens3 --direction=in --no-promiscuous-mode --packet-buffered --immedi>
Jul 16 07:26:34 maas4 rackd[9197]: provisioningserver.rpc.clusterservice: [info] Region is not advertising RPC endpoints. (Wh>
Jul 16 07:26:35 maas4 rackd[9197]: provisioningserver.rpc.clusterservice: [info] Region is not advertising RPC endpoints. (Wh>
Jul 16 07:26:36 maas4 rackd[9197]: provisioningserver.rpc.clusterservice: [info] Region is not advertising RPC endpoints. (Wh>
Jul 16 07:26:37 maas4 rackd[9197]: provisioningserver.rpc.clusterservice: [info] Region is not advertising RPC endpoints. (Wh>
$ sudo systemctl status maas-regiond.service
● maas-regiond.service - MAAS Region Controller
     Loaded: loaded (/lib/systemd/system/maas-regiond.service; enabled; vendor preset: enabled)
     Active: active (running) since Tue 2024-07-16 07:25:41 UTC; 1min 3s ago
       Docs: https://maas.io/docs/
   Main PID: 9155 (regiond)
      Tasks: 2 (limit: 9388)
     Memory: 1.0G
        CPU: 40.310s
     CGroup: /system.slice/maas-regiond.service
             └─9155 /usr/bin/python3 /usr/sbin/regiond
Jul 16 07:25:48 maas4 regiond[9155]: maasserver.models.signals.staticipaddress: [info] Removed orphan DNS record 'win-vvu5qf9>
Jul 16 07:25:48 maas4 regiond[9155]: maasserver.models.signals.staticipaddress: [info] Removed orphan DNS record 'win-ti2grms>
Jul 16 07:25:48 maas4 regiond[9155]: maasserver.models.signals.staticipaddress: [info] Removed orphan DNS record 'rtemplate.m>
Jul 16 07:25:48 maas4 regiond[9155]: maasserver.models.signals.staticipaddress: [info] Removed orphan DNS record 'rhel9-demo.>
Jul 16 07:25:48 maas4 regiond[9155]: maasserver.models.signals.staticipaddress: [info] Removed orphan DNS record 'storage-tes>
Jul 16 07:25:48 maas4 regiond[9155]: maasserver.models.signals.staticipaddress: [info] Removed orphan DNS record 'ubuntu-serv>
Jul 16 07:25:48 maas4 regiond[9155]: maasserver.models.signals.staticipaddress: [info] Removed orphan DNS record 'mx-one.maas
Ping can’t solve the fqdn address.
% ping maas4.maas
ping: cannot resolve maas4.maas: Unknown host
I didn’t answer this question.
I waited for about 5-6 minutes.
Oh!
After waiting for about 15 minutes, the MAAS dashboard was displayed.
FYI in 3.5.0 we moved the images from the DB to the disk of the regions and this might require some time immediately after the upgrade.
Also, I noticed now that you are using deb. For debs the logs are under
journalctl -t regiond
while for snaps are under
Thank you for reporting back that everything looks fine atm. In case you hit issues, please let us know!
Thank you for your help!
