Hello MAAS,
I tried to update block devices tags on a deployed system, and get the following error:
maas $profile block-device add-tag $system $bid tag=ceph
Cannot update block device because the machine is not Ready.
I don’t see limitation on this docs about this, https://maas.io/docs/how-to-use-storage-tags
Is there a way to update block devices tags on an already running system ?
Context: Sunbeam is making use of block device tags to enroll disks into microceph.
A user in sunbeam matrix channel wants to enroll additional disks in microceph, after having the node already deployed. The solution of updating the block device tags does not work.
