On an enlisted machine I have a number of physical disks. I commission the machine with ‘Preserve Storage Configuration’ as there is existing data I’ve pre-seeded for workloads after deployment.
To deploy, I have several physical disks, and used only one of those on the commissioned node (mounted as /) for deployment of the OS.
On the deployed machine, it’s my intention to mount the remaining disks post-deployment during a configuration pass. During my tests the remaining disks are visible to the OS (in lsblk, parted) but all have "Unrecognised disk label’ and “Partition Table: Unknown” in parted.
I had presumed that if I leave a disk unused in MAAS that it doesn’t get modified, but is this not the case?
MAAS instructs Curtin to wipe the superblock of all known disks. This is done in case the previous deployment uses the same labels as the new deployment and to prevent other conflicts. MAAS can only instruct Curtin to wipe the superblock for disks it knows about. Deleting the disk from MAAS will prevent them from being wiped.
Note: Disk erasing upon release erases all disks on the system regardless of whether or not they are modeled in MAAS.
