Hello All,
I am trying to import Ubuntu 22.04 into MaaS through the Web UI and and when I select 22.04 amd64 and click Update Selection, It is able to download the image and then it gets stuck on “Waiting for rack controller(s) to sync” where it gets stuck in perpetuity. In looking at the logs, I do see this message pop up in the rackd.log right at the time the download completes and it moves on to the next step.
2022-10-14 18:57:50 twisted.internet.defer: [critical] Unhandled error in Deferred:
File "/snap/maas/23947/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 501, in errback
self._startRunCallbacks(fail)
File "/snap/maas/23947/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 568, in _startRunCallbacks
self._runCallbacks()
File "/snap/maas/23947/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 654, in _runCallbacks
File "/snap/maas/23947/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 1475, in gotResult
_inlineCallbacks(r, g, status)
File "/snap/maas/23947/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 1416, in _inlineCallbacks
result = result.throwExceptionIntoGenerator(g)
File "/snap/maas/23947/usr/lib/python3/dist-packages/twisted/python/failure.py", line 491, in throwExceptionIntoGenerator
File "/snap/maas/23947/lib/python3.8/site-packages/provisioningserver/rpc/boot_images.py", line 153, in _import_boot_images
yield deferToThread(_run_import, sources, maas_url, **proxies)
File "/snap/maas/23947/usr/lib/python3/dist-packages/twisted/python/threadpool.py", line 250, in inContext
result = inContext.theWork()
File "/snap/maas/23947/usr/lib/python3/dist-packages/twisted/python/threadpool.py", line 266, in <lambda>
File "/snap/maas/23947/usr/lib/python3/dist-packages/twisted/python/context.py", line 122, in callWithContext
File "/snap/maas/23947/usr/lib/python3/dist-packages/twisted/python/context.py", line 85, in callWithContext
return func(*args,**kw)
File "/snap/maas/23947/lib/python3.8/site-packages/provisioningserver/utils/twisted.py", line 202, in wrapper
File "/snap/maas/23947/lib/python3.8/site-packages/provisioningserver/rpc/boot_images.py", line 117, in _run_import
imported = boot_resources.import_images(sources)
File "/snap/maas/23947/lib/python3.8/site-packages/provisioningserver/import_images/boot_resources.py", line 166, in import_images
image_descriptions = download_all_image_descriptions(
File "/snap/maas/23947/lib/python3.8/site-packages/provisioningserver/import_images/download_descriptions.py", line 343, in download_all_image_descriptions
repo_boot = download_image_descriptions(
File "/snap/maas/23947/lib/python3.8/site-packages/provisioningserver/import_images/download_descriptions.py", line 333, in download_image_descriptions
dumper.sync(reader, rpath)
File "/snap/maas/23947/lib/python3.8/site-packages/provisioningserver/import_images/download_descriptions.py", line 201, in sync
super().sync(reader, path)
File "/snap/maas/23947/usr/lib/python3/dist-packages/simplestreams/mirrors/__init__.py", line 86, in sync
data = util.load_content(payload)
File "/snap/maas/23947/usr/lib/python3/dist-packages/simplestreams/util.py", line 332, in load_content
return json.loads(content)
File "/usr/lib/python3.8/json/__init__.py", line 357, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.8/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.8/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
I am running version 3.2.6
I have not noticed any other issues other than this.
I appreciate and help or guidance anyone could give me with this. I am not exactly a maas expert, I just know enough to break things.
Thank you,
Salvatore
