I have tried 3.0, the problem persists.
I’m sure that my nvme is always there, never beging replaced/unplaged. And I tried re-commission over and over but always get the same result.
In order to figure out what’s happeded, I checked the source of curtin(commit 818db25799d85d273a0da69075f77dc2b7c1127f), I found this:
# block_meta.py line 450:
volume_path = block.lookup_disk(vol_value) # vol_value = '202101260446' according to the log.
# block\__init__.py
def lookup_disk(serial):
# line 926:
disks = list(filter(lambda x: serial_udev in x,
os.listdir("/dev/disk/by-id/")))
if not disks or len(disks) < 1:
raise ValueError("no disk with serial '%s' found" % serial_udev)
According to the code, I checke whether /dev/disk/by-id/202101260446 exists or not. The result is NOT.
But there do exists some symbol links:
root@pc1:/home/ubuntu# tree /dev/disk/by-id/
/dev/disk/by-id/
├── nvme-Asgard_AN3_2TNVMe-M.2
│ └── 80_202101260446 -> ../../../nvme0n1
└── nvme-nvme.126f-323032313031323630343436-41736761726420414e332032544e564d652d4d2e322f3830-00000001 -> ../../nvme0n1
So I guess either the config passed to curtin or curtin itself needs improves.
I keep seeking and find a config-000.cfg is passed to curtin which contains:
storage:
config:
- grub_device: true
model: Asgard AN3 2TNVMe-M.2/80
ptable: gpt
serial: '202101260446'
type: disk
wipe: superblock
That one is exactly the config shown in log.
But my work of seeking config stops here because I’m not yet figure how curtin get these configs from MAAS.
So I started from another side. After checking source code of MAAS, I found an executable /snap/maas/13107/usr/share/maas/machine-resources/amd64.
I guess that this is the tool for generating config and pass it to curtin.
But what superised me is that if I run it manually under target machine(rescue mode), I got the following result:
"storage": {
"disks": [
"id": "nvme0n1",
"device": "259:0",
"model": "Asgard AN3 2TNVMe-M.2/80",
"type": "nvme",
"read_only": false,
"size": 2048408248320,
"removable": false,
"wwn": "nvme.126f-323032313031323630343436-41736761726420414e332032544e564d652d4d2e322f3830-00000001",
"numa_node": 0,
"device_path": "pci-0000:01:00.0-nvme-1",
"block_size": 512,
"firmware_version": "42A7T36A",
"rpm": 0,
"serial": "202101260446",
"device_id": "nvme-nvme.126f-323032313031323630343436-41736761726420414e332032544e564d652d4d2e322f3830-00000001",
"partitions": []
Which seems the device_id is definily correct.
So, either the config MAAS passed to curtin (if config is pass from MAAS to curtin) or curtin itself needs improves.
