Ubuntu kernels (UI)
MAAS supports four types of kernels for its Ubuntu machines.
  • General availability kernels
  • Hardware enablement kernels
  • Hardware enablement kernels (pre-release)
  • Low latency kernels
This article explains each of these kernels, and offers instructions and further references regarding their use.
The general availability (GA) kernel is based on the generic kernel that ships with a new Ubuntu version. Subsequent fixes are applied regularly by the ‘daily’ stream used when setting up the global image source for MAAS.
New hardware gets released all the time. If an Ubuntu host runs an older kernel, it’s unlikely that MAAS can support the hardware. Canonical does make every effort to backport more recent kernels enabling more hardware. The acronym HWE stands for “HardWare Enablement.”
Note that these backported/HWE kernels are only available for LTS releases (e.g. Trusty, Xenial, etc.). For example, the first available HWE kernel for Ubuntu 16.04 LTS (Xenial) will be the GA kernel from Ubuntu 16.10 (Yakkety).
Before MAAS 2.1 on Xenial, HWE kernels are referred to by the notation hwe-<release letter>. So, to install the Yakkety HWE kernel on Xenial, the hwe-y kernel is used. By default, when using the web UI, MAAS imports all available HWE kernels along with its generic boot images. So if you are importinTrusty images are imported then the following HWE kernels are included: hwe-u, hwe-v, hwe-w, hwe-x (presuming the Xenial HWE kernel is available).
See MAAS CLI for how to target specific HWE kernels when selecting install images.
Low latency kernels
MAAS denotes a low latency kernel in a few ways:
  • hwe-x-lowlatency: the Xenial low latency HWE kernel for Trusty
  • ga-16.04-lowlatency: the low latency GA kernel for Xenial
  • hwe-16.04-lowlatency: the low latency HWE kernel for Xenial
Using kernels
  • globally (default minimum enlistment and commissioning kernel)
  • per machine (minimum deploy kernel)
  • per machine during deployment (specific deploy kernel)
You can also use the MAAS CLI to make these choices.
Default minimum kernel
To set the default minimum enlistment and commissioning kernel (based on Ubuntu release: GA kernel) for all machines visit the ‘General’ tab of the ‘Settings’ page and select a kernel in the ‘Default Minimum Kernel Version’ field of the Commissioning section. Don’t forget to click ‘Save’.
Machine minimum kernel
To set the minimum deploy kernel on a machine basis, click on a machine from the ‘Machines’ page of the web UI and switch to its ‘Configuration’ page. Click ‘Edit’ in the ‘Machine configuration’ section, select a kernel in the ‘Minimum Kernel’ field followed by ‘Save changes’.
Machine kernel during deployment
To set a specific kernel during deployment, select a machine from the ‘Machines’ page and choose ‘Deploy’ under ‘Take action’. Then choose a kernel from the (third) kernel field. Hit ‘Deploy machine’ to initiate the deployment.
MAAS verifies that the specified kernel is available for the given Ubuntu release (series) before deploying the machine.
