hi guys:
my maas version is 2.6.2
i am control maas by api to deploy a machine.
when i call the deploy api , it will raise error:
2021-10-27 11:21:49 maasserver: [error] ################################ Exception: 'Machine' object is not iterable ################################
2021-10-27 11:21:49 maasserver: [error] Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/django/core/handlers/base.py", line 185, in _get_response
response = wrapped_callback(request, *callback_args, **callback_kwargs)
File "/usr/lib/python3/dist-packages/maasserver/utils/views.py", line 277, in view_atomic_with_post_commit_savepoint
return view_atomic(*args, **kwargs)
File "/usr/lib/python3.6/contextlib.py", line 52, in inner
return func(*args, **kwds)
File "/usr/lib/python3/dist-packages/maasserver/api/support.py", line 70, in __call__
response = upcall(request, *args, **kwargs)
File "/usr/lib/python3/dist-packages/django/views/decorators/vary.py", line 21, in inner_func
response = func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/piston3/resource.py", line 229, in __call__
else: stream = srl.render(request)
File "/usr/lib/python3/dist-packages/piston3/emitters.py", line 464, in render
response = serializers.serialize(format, self.data, indent=True)
File "/usr/lib/python3/dist-packages/django/core/serializers/__init__.py", line 129, in serialize
s.serialize(queryset, **options)
File "/usr/lib/python3/dist-packages/django/core/serializers/base.py", line 80, in serialize
for count, obj in enumerate(queryset, start=1):
TypeError: 'Machine' object is not iterable
2021-10-27 11:21:49 regiond: [info] 127.0.0.1 POST /MAAS/api/2.0/machines/gbcq8k/?op=deploy HTTP/1.1 --> 500 INTERNAL_SERVER_ERROR (referrer: -; agent: python-requests/2.25.1)
i have to restart maas service to workaround。
but it will happen again sometimes。。。。
it just happen occasionly .
with greate appreciate.
my emal is 990967768@qq.com
