The web should more accurately reflect the state of a tested machine
maas admin machine test --help
A node in the 'ready', 'allocated', 'deployed', 'broken', or any failed
state may run tests. If testing is started and successfully passes from
'broken' or any failed state besides 'failed commissioning' the node
will be returned to a ready state. Otherwise the node will return to
the state it was when testing started.
The MAAS CLI help page explicitly states that after tests are completed, if the tests pass, the node’s status will revert to its state before testing. I have also confirmed this through the web UI; for a deployed machine, upon completion of testing, the machine’s status remains in the deployed state. This behavior is by design.
However, there is a scenario where, for a machine already in a deployed state, if during testing you select “allow SSH access and prevent machine powering off,” then upon successful completion of the test, although the machine’s status reverts to deployed, in reality, the machine is running squashfs instead of the actual OS installed on the hard drive.
In this situation, if someone checks the machine’s status via the MAAS CLI (machine read) or the MAAS web , she/he would not be able to know that the machine is actually still running the squashfs introduced by the testing process.
I would like the MAAS web interface to flag this condition to reflect the machine’s true state accurately.
Hi there!
Thank you for bringing this to our attention! This actually seems like a missed edge-case in the CLI and GUI not accurately reporting the state of the machine in this specific instance. If you could please file a bug report for this, we can see about getting this resolved.
Many thanks.
Thank you. I just filed this Bug #2091089 “machine status does not reflect real mahine's stat...” : Bugs : MAAS
Thank you for filing this as a bug report. I will close this topic now as we shall deal with the bug over on LaunchPad.
If you have any further questions or problems, please feel free to open a new topic here.
All the best.
