The following recipes may help you make better use of the MAAS CLI. Each recipe includes the relevant CLI command sequence, with the results processed through jq and other relevant command-line utilities to produce cleaner output. Understand that this material isn’t meant to replace the CLI, just to give you some hints about using it.
Catalog of recipes:
Basic machine list
Machine list sorted by machine name
.boot_interface.links[0].subnet.name]) | @tsv' | column -t \
| sort -k 1
Machine list sorted by system ID
| sort -k 1
Machine list sorted by power state
| sort -k 1
Machine list sorted by machine status
| sort -k 1
Machine list sorted by first tag
| sort -k 1
Machine list sorted by pool
| sort -k 1
Machine list sorted by VLAN
| sort -k 1
Machine list sorted by fabric
| sort -k 1
Machine list sorted by subnet
| sort -k 1
List of VM hosts
maas admin vm-hosts read | jq -r '(["ID","VM-HOST","SYSID","CORES","USED","RAM",
"USED","STORAGE", "USED"] | (., map(length*"-"))), (.[]| [.id,.name,.host.system_id,
.total.cores, .used.cores, .total.memory, .used.memory,.total.local_storage,
.used.local_storage]) | @tsv' | column -t
Creating a KVM with confirmation
Note that most of these can be entered directly at the command line using copy/paste – even the #!/bin/bash won’t hurt, as it will be ignored by the shell.
Remember to:
1. login to the MAAS CLI before using these commands.
2. substitute your administrator profile for “admin” if you’ve assigned a different admin username.
Also, be aware of how multiple lines are parsed by the shell:
Quoted sections, such as the long command generally following
jq, need no special accomodations to break lines. You can break the lines anywhere that’s convenient for you, as long as you maintain at least a single space between “words.” -
Any non-quoted section (i.e., part of a shell command) must have a
\at the end of each line, before a continuation line.
For example, this configuration works fine:
"SYSID",....
....' | column -t
But this one will produce an error:
| jq
-r '(["HOSTNAME",....
We’ve tried to break them so that they fit on an average terminal line, but your mileage may vary.
lsmm series: Listing MAAS machines
The lsmm script, defined below, is something we use to quickly get machine information from the command line. For those of us who prefer the CLI, it’s an easy way to gather the same information you’d get in the web UI machine list, but more focused in each option.
lsmm: List MAAS machines
This recipe prints a basic machine list. Here’s the command to paste into the command line:
And here’s the command as part of the lsmm shellscript:
#!/bin/bash
# lsmm - list maas machines
# make sure to chmod this file so it can execute
If you save this to a file, make sure to chmod the file so it will execute. You might also add it to your path, or perhaps even place it in /usr/bin if desired.
lsmm -t: List MAAS machines with first tag
It’s a good idea to keep your most important machine tag first, as it’s the first one you’ll see. It makes scanning your list (UI or CLI/jq) much more efficient. Here’s a recipe that adds the first tag to the console-printed machine list:
And here’s an expanded version of lsmm that takes a -t options, for “tags:”
#!/bin/bash
# and make sure it's in the path (if you're not typing "./")
if [ -z "$1" ]
then
fi
if [ "$1" == "-t" ]
then
fi
Note that with no option (e.g., just lsmm on the command line), this script will print the basic machine list from the previous recipe.
lsmm --vmhost: List VM hosts
Here’s a recipe that gives a quick overview of your existing VM hosts:
And here it is as part of an expanded lsmm script, under the new option -vmh:
#!/bin/bash
if [ -z "$1" ]
then
fi
if [ "$1" == "-t" ]
then
fi
if [ "$1" == "--vmhost" ]
then
fi
Remember to chmod and path the script so it will run.
lsmm --vmhost -c: List VM host configurable parameters
Here’s a command line recipe to list the configurable parameters of a specific host:
maas admin vm-host read $ID | jq -r '(["ID","NAME","POOL","ZONE",
"CPU-O/C", "RAM-O/C", "TAGS"] | (., map(length*"-"))), (.| [.id,.name,
.pool.name, .zone.name,.cpu_over_commit_ratio,
.memory_over_commit_ratio, .tags[]]) | @tsv' | column -t
where $ID is the VM host ID (not the System ID; run lsmm --vmhost if you’re not sure). Here’s an updated version of lsmm with the -vmhost -c options:
#!/bin/bash
# for the "-vmhost -c" option, don't forget to type $3 as the ID of the VM host
if [ -z "$1" ]
then
elif [ "$1" == "-t" ]
then
elif [ "$1" == "--vmhost" -a -z "$2" ]
then
elif [ "$1" == "--vmhost" -a "$2" == "-c" ]
then
maas admin vm-host read $3 | jq -r '(["ID","NAME","POOL","ZONE",
fi
Don’t forget to invoke this script with two parameters, like this:
lsmm --vmhost -c $ID
So if your desired VM host is ID 4, you’d type:
lsmm --vmhost -c 4
mkmm series: Creating MAAS machines
The following scripts walk you through creating MAAS machines of various types. In these simple recipes, there’s no validation of input, so use at your own risk – although it would be trivial to add validation for your favorite machine types.
mkmm --kvm: Make a libvirt VM
This very basic recipe creates a libvirt virtual machine. The parameters can be entered interactively (mkmm --kvm -i) or in “batch” mode (for scripting commands in a batch shellscript) by using mkmm --kvm -b:
#!/bin/bash
# mkmm -- make MAAS machines
# --kvm = create a libvirt KVM
# -i = interactive mode
# -b = batch mode
if [ "$1" == "--kvm" -a "$2" == "-i" ]
then
read -p "architecture? " arch
read -p "MAC address? " macaddr
read -p "power ID? " powerid
read -p "power address? " poweraddr
read -p "power password? " powerpw
maas admin machines create \
architecture=$arch \
mac_addresses=$macaddr \
power_type=virsh \
power_parameters_power_id=$powerid \
power_parameters_power_address=$poweraddr \
power_parameters_power_pass=$powerpw
elif [ "$1" == "--kvm" -a "$2" == "-b" ]
then
architecture=$3 \
mac_addresses=$4 \
power_type=virsh \
power_parameters_power_id=$5 \
power_parameters_power_address=$6 \
power_parameters_power_pass=$7
fi
In interactive mode, the script prompts you for all needed parameters; note that the power type isn’t needed, because it’s “virsh” in this case. Interactive mode looks like this:
stormrider@wintermute:tmp$ mkmm --kvm -i
architecture? amd64
MAC address? 52:54:00:1e:a5:7e
power ID? e9f84356-5106-40ee-9088-3e35ec7d50cf
power address? qemu+ssh://stormrider@192.168.123.1/system
power password? xxxxxxx
If you prefer to batch your machine creation in shellscripts, you can use the -b option instead, like this:
#!/bin/bash
mkmm --kvm -i amd64 52:54:00:1e:a5:7e e9f84356-5106-40ee-9088-3e35ec7d50cf qemu+ssh://stormrider@192.168.123.1/system xxxxxxx
This mode allows you to add a number of lines to a longer shellscript, facilitating automatic creation or even the use of a makefile (if you’re creative).
