Delete static route
maas $PROFILE static-route delete [--help] [-d] [-k] id [data ...]
Positional arguments
- id
Deletes the static route with the given ID.
Command-line options
| Option | Effect |
Get a static route
maas $PROFILE static-route read [--help] [-d] [-k] id [data ...]
- id
Gets a static route with the given ID.
| Option | Effect |
Update a static route
maas $PROFILE static-route update [--help] [-d] [-k] id [data ...]
- id
Updates a static route with the given ID.
Keyword “source”
Optional String. Source subnet name for the route.
Keyword “destination”
Optional String. Destination subnet name for the route.
Keyword “gateway_ip”
Optional String. IP address of the gateway on the source subnet.
Keyword “metric”
Optional Int. Weight of the route on a deployed machine.
| Option | Effect |
Create a static route
maas $PROFILE static-routes create [--help] [-d] [-k] [data ...]
Creates a static route.
Keyword “source”
Required String. Source subnet name for the route.
Required String. Destination subnet name for the route.
Required String. IP address of the gateway on the source subnet.
Keyword “metric”
| Option | Effect |
List static routes
maas $PROFILE static-routes read [--help] [-d] [-k] [data ...]
Lists all static routes.
| Option | Effect |
