Is there a way to assign a static IP to a device (switch/router/non-MAAS managed machine) so that I only have to manage DHCP and IP allocations through the MAAS UI?
I’m using MAAS 2.6
I’m using MAAS 2.6
Nevermind, it looks like just by adding a device with a MAC address and a static IP is all I had to do. It’s just confusing that this is not mentioned anywhere in the documentation and in the UI if you try to “Edit physical” on the interface it kind of shows as it’s not working (but it is on the dhcpd side).
