Set up SSH
For MAAS to successfully communicate with libvirt on your KVM host machine, this example command must succeed from every rack controller as user maas
virsh -c qemu+ssh://$USER@$KVM_HOST/system list --all
Here, $USER
is a user on your KVM host who is a member of the libvirtd
Unix group on the KVM host, and $KVM_HOST
is the IP of your KVM host.
MAAS package installs
The maas
user on your rack controllers will issue all virsh commands. Therefore, you’ll need to set up SSH public keys on every rack controller for user maas
If you installed MAAS via packages, first create SSH keys on all rack controllers:
sudo chsh -s /bin/bash maas
sudo su - maas
ssh-keygen -t rsa -N ''
Next, add the contents of ~maas/.ssh/id_rsa.pub
to the KVM host user’s ~$USER/.ssh/authorized_keys
. To accomplish this, log into your KVM host node, via SSH, from a host for which MAAS has a matching public SSH key.
MAAS snap installs
sudo mkdir -m 0700 -p /var/snap/maas/current/root/.ssh
sudo ssh-keygen -f id_rsa
Finally, you’ll need to add id_rsa.pub
to the authorized_keys
file in /home/<kvm-host-user-homedir-name>/.ssh/
, where <kvm-host-user-homedir-name>
is the name of your KVM host user.
Insufficient permissions for $USER
may cause the virsh
command to fail with an error such as failed to connect to the hypervisor
. Check the $USER
group membership to make sure $USER
group.
