Spaces and fabrics are nothing more than network groupings. They are used to group network elements together:
- Fabrics group VLANs, so they act like a Layer 2 (Link Layer) category.
- Spaces group subnets, so they act like a Layer 3 (Network Layer) category.
- In fact, the mechanics are much more complicated, so (1) and (2) are useful generalisations only.
Let’s get about proving that to ourselves.
Spaces are created without association
In MAAS, spaces are created without any association with any other network element, as this help listing shows:
usage: maas admin spaces create [--help] [-d] [-k] [data [data ...]]
Create a space
This method accepts keyword arguments. Pass each argument as a
key1=value1 key2=value key3=value3. Keyword arguments must come after
any positional arguments.
Create a new space.
:param name: Required. The name of the new space.
:type name: String
:param description: Optional. A description of the new
space.
:type description: String
Common command-line options:
--help, -h
Show this help message and exit.
-d, --debug
Display more information about API responses.
-k, --insecure
Disable SSL certificate check
You can infer that spaces do not carry associations themselves, due to the lack of any named parameters that would let you add those associations.
Subnets can join a space; they are always in a VLAN and a fabric
You can associate a space with a subnet like this:
usage: maas admin subnet update [--help] [-d] [-k] id [data [data ...]]
Update a subnet
Positional arguments:
id
Update a subnet with the given ID.
:param cidr: Optional. The network CIDR for this
subnet.
:type cidr: String
:param name: Optional. The subnet's name.
:type name: String
:param description: Optional. The subnet's
description.
:param vlan: Optional. VLAN this subnet belongs to.
Defaults to the default VLAN for the provided fabric or defaults to the
default VLAN in the default fabric (if unspecified).
:type vlan: String
:param fabric: Optional. Fabric for the subnet.
Defaults to the fabric the provided VLAN belongs to, or defaults to the
default fabric.
:type fabric: String
:param vid: Optional. VID of the VLAN this subnet belongs
to. Only used when vlan is not provided. Picks the VLAN with this VID
in the provided fabric or the default fabric if one is not given.
:type vid: Int
:param space: Optional. Space this subnet is in.
Defaults to the default space.
:type space: String
:param gateway_ip: Optional. The gateway IP address
for this subnet.
:type gateway_ip: String
:param rdns_mode: Optional. How reverse
DNS is handled for this subnet. One of:
- ``0`` Disabled: No reverse zone is created.
- ``1`` Enabled: Generate reverse zone.
- ``2`` RFC2317: Extends '1' to create the necessary parent zone with
the appropriate CNAME resource records for the network, if the the
network is small enough to require the support described in RFC2317.
:type rdns_mode: Int
:param allow_dns: Optional. Configure MAAS DNS to allow
DNS resolution from this subnet. '0' == False,'1' == True.
:type allow_dns: Int
:param allow_proxy: Optional. Configure maas-proxy to
allow requests from this subnet. '0' == False, '1' == True.
:type allow_proxy: Int
:param dns_servers: Optional. Comma-separated list of
DNS servers for this subnet.
:type dns_servers: String
:param managed: Optional. In MAAS 2.0+,
all subnets are assumed to be managed by default.
:type managed: Int
:param disabled_boot_architectures: Optional. A comma
or space separated list of boot architectures which will not be
responded to by isc-dhcpd. Values may be the MAAS name for the boot
architecture, the IANA hex value, or the isc-dhcpd octet.
Only managed subnets allow DHCP to be enabled on their related dynamic
ranges. (Thus, dynamic ranges become "informational only"; an
indication that another DHCP server is currently handling them, or that
MAAS will handle them when the subnet is enabled for management.)
Managed subnets do not allow IP allocation by default. The meaning of a
"reserved" IP range is reversed for an unmanaged subnet. (That is, for
managed subnets, "reserved" means "MAAS cannot allocate any IP address
within this reserved block". For unmanaged subnets, "reserved" means
"MAAS must allocate IP addresses only from reserved IP ranges."
:type disabled_boot_architectures: String
--help, -h
-d, --debug
-k, --insecure
Note the optional parameter space in the list:
:type space: String
This is a little bit misleading, because if you haven’t defined a space, the default space is undefined, which is, in reality, not a space.
You might also note the optional parameter fabric in this list:
default fabric.
In this case, the fabric does default to the default fabric, which is usually fabric-0.
In MAAS, VLANs always exist in some fabric, but can join a space
You can also associate a VLAN with a space, like this:
usage: maas admin vlan update [--help] [-d] [-k]
fabric_id vid [data [data ...]]
Update VLAN
fabric_id
vid
Updates a given VLAN.
:param name: Optional. Name of the VLAN.
:type name: String
:param description: Optional. Description of the VLAN.
:param mtu: Optional. The MTU to use on the VLAN.
:type mtu: Int
:param dhcp_on: Optional. Whether or not DHCP should
be managed on the VLAN.
:type dhcp_on: Boolean
:param primary_rack: Optional. The primary rack
controller managing the VLAN (system_id).
:type primary_rack: String
:param secondary_rack: Optional. The secondary rack
:type secondary_rack: String
:param relay_vlan: Optional. Relay VLAN ID. Only set when
this VLAN will be using a DHCP relay to forward DHCP requests to
another VLAN that MAAS is managing. MAAS will not run the DHCP relay
itself, it must be configured to proxy requests to the primary and/or
secondary rack controller interfaces for the VLAN specified in this
field.
:type relay_vlan: Int
:param space: Optional. The space this VLAN should be
placed in. Passing in an empty string (or the string 'undefined') will
cause the VLAN to be placed in the 'undefined' space.
:type space: String
--help, -h
-d, --debug
-k, --insecure
Again, the operative parameter is here:
:type space: String
But note that the fabric_id is required to update the VLAN. It is also required to create the VLAN:
usage: maas admin vlans create [--help] [-d] [-k] fabric_id [data [data ...]]
Create a VLAN
fabric_id
Creates a new VLAN.
:type name: String
:param description: Optional. Description of the new
VLAN.
:param vid: Required. VLAN ID of the new VLAN.
:type vid: Int
:type mtu: Int
:type space: String
--help, -h
-d, --debug
-k, --insecure
In other words, within MAAS, VLANs always exist within a fabric, even if it’s the default fabric.
No other MAAS element can be assigned to a space or fabric
Using the CLI help and parameters as a guide, nothing else in the maas admin -h listing can be associated with a space or a fabric, other than what’s listed above.
A fabric can group VLANs
We can test this with the following commands.
Create a unique fabric
stormrider@cloudburst:~$ maas admin fabrics create name="new-fabric"
"class_type": null,
"id": 62,
"name": "new-fabric",
"vlans": [
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"external_dhcp": null,
"relay_vlan": null,
"secondary_rack": null,
"id": 5064,
"space": "undefined",
"primary_rack": null,
"fabric": "new-fabric",
"fabric_id": 62,
"name": "untagged",
"resource_uri": "/MAAS/api/2.0/vlans/5064/"
"resource_uri": "/MAAS/api/2.0/fabrics/62/"
Note that this fabric is automatically assigned to the default VLAN (vid 0, aka untagged). So in reality, a fabric can’t exist in MAAS separate from some VLAN.
Create a new, unique subnet
stormrider@cloudburst:~$ maas admin subnets create cidr="10.194.15.0/24"
"name": "10.194.15.0/24",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"id": 5004,
"fabric": "fabric-0",
"fabric_id": 0,
"name": "untagged",
"cidr": "10.194.15.0/24",
"rdns_mode": 2,
"gateway_ip": "",
"dns_servers": [],
"allow_dns": true,
"allow_proxy": true,
"active_discovery": false,
"managed": true,
"disabled_boot_architectures": [],
"id": 12,
"resource_uri": "/MAAS/api/2.0/subnets/12/"
Note that this subnet is also assigned to the default VLAN when created. This means that every fabric always has an associated VLAN, and every subnet always has an associated VLAN. But look at what we just did. We have a subnet on the untagged VLAN associated with fabric-0, and we also have the untagged VLAN associated with fabric-62, aka new-fabric. So two different fabrics can access the same VID (but reach different subnets by so doing).
Assign the new fabric and subnet separately
The fabric is already associated with the VLAN, so we just need to do this:
stormrider@cloudburst:~$ maas admin subnet update 12 fabric=60
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"id": 5004,
"fabric_id": 0,
"name": "untagged",
"rdns_mode": 2,
"gateway_ip": "",
"dns_servers": [],
"allow_dns": true,
"managed": true,
"id": 12,
This returns information as if it worked, with a “success” message, but in fact did not change the fabric of this subnet. You’ll see that it remains in fabric-0. We can understand how this works by trying this in the UI. If we use the UI to assign a subnet to a fabric, we are required to choose a specific VLAN for the subnet in order for the update to complete. Otherwise, MAAS just ignores the change, returns no error message, does not change the subnet associated with a fabric, and goes on about its business.
What we just learned
So here’s the logic associated with what we just did:
- A subnet always has a VLAN, even if it’s the default.
- A VLAN always has a fabric, even if it’s the default.
- Therefore, a subnet is always reachable thru a fabric.
You can confirm this by listing the contents of, say, fabric=60, like this:
"class_type": null,
"vlans": [
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"name": "untagged",
"fabric_id": 60,
"fabric": "fabric-one",
"id": 5061,
"resource_uri": "/MAAS/api/2.0/vlans/5061/"
"vid": 100,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"name": "vlan-alpha",
"fabric_id": 60,
"id": 5062,
"resource_uri": "/MAAS/api/2.0/vlans/5062/"
"name": "fabric-one",
"id": 60,
"resource_uri": "/MAAS/api/2.0/fabrics/60/"
Note that this doesn’t actually show any subnets, only VLANs. So fabrics group VLANS, not subnets, and thus they would generally be considered a Layer 2 construct, since by inference only, they depend on the P/Q tags in the Ethernet frame (the layer two PDU).
VLANs without subnets?
Okay, can we create a VLAN that has no subnets? Well, let’s see. The help for VLAN creation tells us this:
stormrider@cloudburst:~$ maas admin vlans create -h
Create a VLAN
fabric_id
Creates a new VLAN.
:type name: String
VLAN.
:type vid: Int
:type mtu: Int
:type space: String
--help, -h
-d, --debug
-k, --insecure
Creating an empty VLAN?
So if we issue a command like this:
stormrider@cloudburst:~$ maas admin vlans create 61 vid=4000
"vid": 4000,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"id": 5065,
"name": "4000",
"fabric": "fabric-two",
"fabric_id": 61,
"resource_uri": "/MAAS/api/2.0/vlans/5065/"
…it appears to work. If we take a look at the MAAS UI, we’ll see that fabric-two (id=61) has a VLAN with vid=4000, but no associated subnet. So currently, fabric-two can reach two VLANs, but no subnets.
Grouping things with spaces
Okay, so let’s try these same exercises with spaces. We already created a space called space-1, which we have available to connect with subnets and VLANs. Let’s try something – let’s associate a specific subnet on the default VLAN with a space, but not directly associate it with the VLAN, and see what happens.
The command looks like this:
stormrider@cloudburst:~$ maas admin subnet update 13 space="space-1"
{"space": ["Spaces may no longer be set on subnets. Set the space on the underlying VLAN."]}
Oops. So this used to work, but it doesn’t any more. Well, the only other option is a VLAN, so let’s try that command:
stormrider@cloudburst:~$ maas admin vlan update 61 0 space=1
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"id": 5063,
"space": "space1",
"fabric_id": 61,
"name": "untagged",
"resource_uri": "/MAAS/api/2.0/vlans/5063/"
So, note that we had to put in both a fabric id and a VLAN id in order to assign a space. Both coordinates are required to correctly locate the entity to be included in the space. Also notice that there doesn’t have to be a subnet associated with this VLAN – although without a subnet, the space can’t actually do anything useful when it’s addressed by Juju.
Okay, this command appears to work, and we can confirm it with the UI. If we look at the untagged VLAN (vid=0) in any other fabric (like, for example, in fabric-0), the space is still undefined. But if we look at the untagged VLAN (same vid) in fabric-two (id=61), we see the space is assigned to space1. Even VLAN 4000, which is also in fabric-two, doesn’t have a defined space.
So if we add a subnet to the untagged VLAN in fabric-two, we’ll be able to reach only that subnet with space1, even though it’s still the untagged VLAN. Before we do that, let’s do a little detective work on space1:
stormrider@cloudburst:~$ maas admin space read 1
"resource_uri": "/MAAS/api/2.0/spaces/1/",
"id": 1,
"name": "space1",
"vlans": [
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"id": 5063,
"name": "untagged",
"fabric_id": 61,
"space": "space1",
"subnets": []
Yep, that’s what’s happening. space1 addresses only those subnets that are part of the untagged VLAN and also in fabric-two. So a fabric matters for a space, but a space means nothing to a fabric.
Okay, let’s test that subnet thing: let’s create a subnet on fabric-two:
stormrider@cloudburst:~$ maas admin subnets create cidr="10.198.16.0/24" fabric=61
"name": "10.198.16.0/24",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"id": 5063,
"name": "untagged",
"fabric_id": 61,
"space": "space1",
"cidr": "10.198.16.0/24",
"rdns_mode": 2,
"gateway_ip": "",
"dns_servers": [],
"allow_dns": true,
"managed": true,
"id": 15,
"space": "space1",
"resource_uri": "/MAAS/api/2.0/subnets/15/"
And let’s check the UI to see if what we thought would happen actually happened. Yep, that’s what happened. If I look at space1 in the UI, it shows me a list of subnets in this space. I can do the same thing by repeating the above command:
"vlans": [
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"id": 5063,
"space": "space1",
"fabric_id": 61,
"name": "untagged",
"id": 1,
"subnets": [
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"id": 5063,
"space": "space1",
"fabric_id": 61,
"name": "untagged",
"rdns_mode": 2,
"gateway_ip": null,
"dns_servers": [],
"allow_dns": true,
"managed": true,
"id": 15,
"space": "space1",
"name": "space1",
So, in fact, the Juju statement that spaces group subnets is true. And it’s also true that fabrics essentially group VLANs – except that fabrics are required to pinpoint spaces.
What can we conclude?
So if you study this carefully, you’ll see that the following global statements are true:
- VLANs are always in a fabric, by default.
- Subnets are always in a VLAN, by default.
- Spaces group subnets, so they act like a Layer 3 (Network Layer) category. But the mechanics of this are, in fact, slightly more complicated, because spaces select subnets based on the VLAN and fabric.
How to use this information
So what can we do with this? Well:
If you want to create a group of specific VLANs, create a new fabric and put them all in that fabric.
If you want to create a group of specific subnets, make sure they can be independently selected by fabric/VLAN combinations; then create a new space and associate that space with the relevant combinations.
There you have it: spaces vs. fabrics.
