Hello guys,
It happened some time that I fail my network config once the node is correctly deployed (I was able to SSH after deployment) and so the node is not able to join maas at next boot.
I have a login ready to use through IPMI console to solve this but I have to wait for the node to be ready.
There is a lot of :
It can last 20min or more !
Is there a way to skip those ones ? Something like "If connection to maas timeout, just boot locally "
In that case it is even faster to release node et deploy it again, but all of this is time consuming.
Am I missing something here ?
Thank you,
Ludwig
