Hi All,
I am new to MAAS and installed MAAS snap in an ubuntu server VM using POC configurations and able to detect physical servers in my rack. I did read in MAAS documentation that if a VM booted using Network PXE then MAAS should be able to install OS on it.
I tried using below setup and MAAS VM is able to discover the VM2 when it boots up in network PXE mode
But it is just in discover mode under MAAS UI but not under Machines Tab. Ideally it should be detected under Machines section so that we can start commissioning process. Right ?
In VM2 it waits for a while in Network PXE boot format and then exits as shown below
Am I missing any steps here ?
