I am in a situation where I need to set up the networking Fabric based on the local ipv4 that is self assigned when the DHCP server or manual config is unavailable (RFC 3927), or based on the VLAN ID sent by LLDP.
Can this be done? I am not finding anything in the documentation that would clear this for me, I tried multiple methods including having the subnet 169.254.0.0/16 set on a default vlan in a Fabric but it doesn’t seem to yeld results.
Any advice is greatly appreciated.
Thank you.
To give more information about my problem:
I have 2 links in 2 switches, my goal at this stage is for MAAS to commission the server and correctly associate the storage interfaces with my existing storage fabric without manually intervening.
The storage links are physically up but cannot pass traffic.
Both storage links as physically up, but the server cannot get normal network connectivity through them during commissioning because they are not in a bond.
So what happens is as follows:
The server boots into commissioning.
Its storage NICs come up physically.
The server doesn’t have configured the intended bond as I don’t see a way to automatically make that bond.
The switch ports are configured to participate in LACP, but no valid aggregation is established.
Storage traffic, including DHCP requests, cannot reach the expected network.
DHCP times out, and the operating system assigns a link-local address.
MAAS creates a new fabric for each link instead of assigning the storage fabric that I want there.
I have the LLDP output where I can see the default untagged vlan and the switch name via it but I don’t see a way to automatically assign links based on this.
What I’m trying to achieve is get the storage links in the correct fabric based on the:
- Link-local ip address
- Vlan ID
- Switch name ( or other information that I can gather via LLDP)
If there is any solution to this please that I’m missing please let me know.
Thank you very much.
