just in case someone comes looking after this, I finally get something to work with this file:
#cloud-config
debconf_selections:
maas: |
{{for line in str(curtin_preseed).splitlines()}}
{{line}}
{{endfor}}
early_commands:
{{if third_party_drivers and driver}}
{{py: key_string = ''.join(['\\x%x' % x for x in driver['key_binary']])}}
{{if driver['key_binary'] and driver['repository'] and driver['package']}}
driver_00_get_key: /bin/echo -en '{{key_string}}' > /tmp/maas-{{driver['package']}}.gpg
driver_01_add_key: ["apt-key", "add", "/tmp/maas-{{driver['package']}}.gpg"]
{{endif}}
{{if driver['repository']}}
driver_02_add: ["add-apt-repository", "-y", "deb {{driver['repository']}} {{node.get_distro_series()}} main"]
{{endif}}
{{if driver['package']}}
driver_03_update_install: ["sh", "-c", "apt-get update --quiet && apt-get --assume-yes install {{driver['package']}}"]
{{endif}}
{{if driver['module']}}
driver_04_load: ["sh", "-c", "depmod && modprobe {{driver['module']}} || echo 'Warning: Failed to load module: {{driver['module']}}'"]
{{endif}}
{{else}}
driver_00: ["sh", "-c", "echo third party drivers not installed or necessary."]
{{endif}}
write_files:
# Create the vtkops user
userconfig:
path: /etc/cloud/cloud.cfg.d/99-opsuser.cfg
content: |
users:
- name: opsuser
sudo: ALL=(ALL) NOPASSWD:ALL
shell: /bin/bash
lock_passwd: true
ssh_authorized_keys:
- ssh-rsa .....
late_commands:
maas: [wget, '--no-proxy', {{node_disable_pxe_url|escape.json}}, '--post-data', {{node_disable_pxe_data|escape.json}}, '-O', '/dev/null']
driver_00_key_get: curtin in-target -- sh -c "/bin/echo -en '{{key_string}}' > /tmp/maas-{{driver['package']}}.gpg"
driver_02_key_add: ["curtin", "in-target", "--", "apt-key", "add", "/tmp/maas-{{driver['package']}}.gpg"]
{{endif}}
driver_03_add: ["curtin", "in-target", "--", "add-apt-repository", "-y", "deb {{driver['repository']}} {{node.get_distro_series()}} main"]
{{endif}}
driver_04_update_install: ["curtin", "in-target", "--", "apt-get", "update", "--quiet"]
driver_05_install: ["curtin", "in-target", "--", "apt-get", "-y", "install", "{{driver['package']}}"]
{{endif}}
driver_06_depmod: ["curtin", "in-target", "--", "depmod"]
driver_07_update_initramfs: ["curtin", "in-target", "--", "update-initramfs", "-u"]
{{endif}}
Honestly I don’t know if I have to leave all those driver_00 to driver_07 I don’t know if they are a sample of what can be done, or the sample is a skeleton of what it is required to implement.
